Washing Machines Logo
Matthew Gillespie Posted on Sep 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't my LG front load washer machine spin?
Keep getting a LE error on LG WM2487HWMA Front Loader Washer Machine. I have replaced the hall sensor, the main control board, the STATOR assembly, and the rotor hub. I have inspected the wires for cuts and shorts. My machine still makes a terrible "grinding noise" and will not spin. I say "grinding noise" but I know there isn't any mechanical parts grinding.
  • Matthew Gillespie Sep 25, 2019
    I can turn the drum by hand and it spins freely without any noise or grinding.
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Sep 28, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
870489
Points
8043
Sometimes a "tE" error code looks like an "LE" error code. Is that possible? "tE" is common and simple and cheap to repair.
grinding noise could be a bra underwire, a paperclip or something similar between the inner and outer drums.
keith jones
Level 3:
Master:
  • LG Master 747 Answers
keith jones
LG Master
Level 3:
Master:
Answers
747
Questions
Helped
314768
Points
1478
Could be seized bearings try manually turning the drum
5 Related Answers
Anonymous
  • Posted on Dec 02, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Anonymous
  • 15 Answers
  • Posted on Oct 03, 2008
SOURCE: LG Washer LE Error
I replaced my hall effect sensor about two weeks ago and just hooked the machine back up a few dags ago. My wife ran about 5 loads through it and it shut down with the LE code again!!! I ordered the part from MCM Electronics and they are sending me a replacement part for free since the first one lasted only a day. Hopefully this is the last time I have to replace this part. It would be great if someone knew how to bench test one of those sensors so I could know for sure if my first one is really defective. I always have a hard time believing when a new part fails so soon.
A
Anonymous
  • Posted on Jan 28, 2008
SOURCE: LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Anonymous
  • 5 Answers
  • Posted on Dec 08, 2007
SOURCE: LG washer wm1832c
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Anonymous
  • 77 Answers
  • Posted on Nov 27, 2012
SOURCE: le error code
LE is a locked rotor code, but usually means the sensor is not functioning. replace Hall sensor, if that doesn't fix it make surer the drum turns freely. the rotor never goes bad, and the stator almost never goes bad. replace board if sensor doesn't fix it.
2answers
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
2helpful
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent).
In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in.
On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced.
On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer.
The CORRECT amount of HE (High Efficiency) detergent to be used is as follows:
HE : (2) Tablespoons Per Wash Load
HE 2X : (1) Tablespoon
HE 3X : (1) Teaspoon
USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER
Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv
Follow us: fixitnowsamurai on Facebook
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
2answers
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
I have an LE code on my washer. I tried resetting machine by unplugging. I still get the code. I also tried running the machine without anything in it. It still stops and give LE code. What should I do?
Kevin
5helpful
My washer won't spin. Error shows up LE. what can I do.
Hello
Kevin
LG front loader washer error LE how to fix
probably a defective motor hall sensor. will require dissassembly of motor via rear panel of machine. you will need a #17 socket and breaker bar to remove rotor nut. also, you will then need a #10 socket and driver to remove motor stator. sensor will be underneath attached to stator.
8helpful
I have a LG WASHER,FRONT LOADER WM0532HW KEEPS FLASHING LE,THE DRUM WILL NOT ROTATE
LE stands for locked motor error.  The first thing you should try is simply unplugging the machine for 10 minutes.  If the problem continues the next most likely cause is the hall sensor.  To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum.  Undre that wheel if the stator (motor).  At the bottom there is a sensor that spans about three of the windings.  This is the hall sensor.  It is not very expensive.  If neither of those work you will need to replace the Stator (motor)
5helpful
LG front load machine with LE code and no spin
LE is a locked motor error. Not to worry as 95% of the time this is just a bad hall sensor (motor position sensor). It is very easy for a technician to replace and the cost is very small.
Hope this helps, please rate my solution.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
