It scans and it copies. There are No lights blinking and there is enough ink. I have a HP Deskjet F4100 All-in-One series printer.
1) If it worked before, you can do a system restore to the last time you remember it working which should clear the problem. Also, 2) Check your printer folder (in "Control Panel") and see if it is listed as a "printer" in there. You may need to reinstall the drivers if you don't see it, Sometimes the driver disk has a repair install option.
3) It may not be "check marked" as your default printer device (in printer folder) which you can easily change by right click on its icon and choose "set as default".
