Doc feeder jam, how to fix it
Top loading feature, paper jammed and locked, I can't get it unstuck
Posted by Sharon Rogstad... on
David Gust
    Sergeant:
  • 181 Answers
Hard to help you without the brand and model.
Posted on Sep 24, 2019
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: auto doc feeder (ADF) has 2 little parts on top--can't get back on
I have worked on the same problem, you will need to order a new adf assy because there is no diagram on that or look at another of the same printer to see how it goes back together. Google the the type of printer and adf and you should be able to find the part, they are easy to install.
Posted on Jan 23, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: Paper is jam on the top feeder of Dell 1110
There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
Click on the user guide link .
http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
Printer paper jams can be caused from:
Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 23, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: printer wont load paper. there is a rattling noise and upon restarting it says Doc. feeder Jam
Follow these instructions to clear the jam and replace the jam clearance component.
For the noise issue, see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 22, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: doc feeder jam (hp 3050)
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 17, 2010
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Posted on Aug 13, 2016
Machine says unable to calibrate, claims jammed paper in the doc feeder,
Check the sensor arms and make sure they move freely and are free of paper debris.
Feb 24, 2015 | HP Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
At power on, my bizhub 222 immediately gives me a paper jam error in the top feeder every time the machine is turned on.
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Dec 09, 2010 | Konica Minolta Bizhub 222 Black and White...
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
Scanner will not load from top feeder. Error says paper jam but no paper is jammed into the feeder.
the rollers may be broken, this would give the appearance of the paper jam to the printer
sorry not sure how to fix this one
Oct 09, 2009 | Visioneer 9450 Flatbed Scanner
I have a HP laserjet 3055 all in one printer and its giving me the error message that says Doc. feeder Jam. There isnt anything in the printer. How do I fix it.
The jam it's talking about is in the feeder on top. Check for stuck paper, or a sensor stuck down, in the feeder area on top
Aug 06, 2009 | LaserJet 3052 All-In-One Printer
Printer wont load paper. there is a rattling noise and upon restarting it says Doc. feeder Jam
May 22, 2009 | LaserJet 3052 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Marvin
Marvin
