Question about Coby Televison & Video
Coby tv wont come on just blank dark screen - Coby Televison & Video
Posted by Johnny Webb on
How do I fix a blnk blackscreen ?
check out this website which deals with Coby products, many people having terrible problems with this company's products and they are not backing up with solutions. Best to dump set and get a different one.
http://coby-tv-reviews.measuredup.com/9211179
Sep 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
I have a black spot on left side of screen, how can I make it go away?
Dead pixels in the LCD wafer; common issue with LCD televisions as they age. Replace the LCD wafer or consider purchasing a new television.
May 23, 2015 | Coby TFTV3225 32 in. LCD TV
50 inch LED flat screen, picture went blank, is there a reset button?
If the picture went blank, either the TV has no signal or something is defective within the TV's electronic components. There is no reset button that will repair a broken TV.
Jun 02, 2014 | Coby Televison & Video
Led tv dark screen, hard to see
tried with adjustment at the set up doesn't work?. if not check weather some of the LED back light are busted.
Oct 10, 2012 | Coby LEDTV1926 19 in. TV
My coby tftv3229 wont turn on and I've only had it
If its two weeks old why are you here? Take it back to point of purchase and either have it fixed or replaced or get a refund.....
From the brand you likely are in UK but here all sets come with some kind of warranty==the problem sounds like a power supply issue but if you have a warranty and open the set it will void that warranty.
Apr 11, 2012 | Coby Televison & Video
I have a Coby dvdtv 1390 that has problems playing dvds. Sometimes it will most times it won't. It will come up with a blank screen or wavy blank screen that says loading. sometimes the discs won't even...
how long has it been since you cleaned the DVD tray? you need to clean after about 10hrs. of play time on a DVD player, just buy a simple cleaning disc at the store, a Walmart, K-mart, Target,....etc....and run it through your player, just follow instructions on package.......I had this problem with my kids ps2, works fine now, the discs you rent are very dirty, and in turn leave your player dirty...hope this helps.....
Jan 06, 2010 | Coby TVDVD1350 13 in. TV/DVD Combo
Remote for TV doesn't light up
Tries better lighting,Glowing in the dark,figure it rare,hard to find.For the bigger keys tries buy a univeral remote,follow ur tv brand and inter the id codes than it operate then u done.
Aug 17, 2009 | Coby TF-TV1912 19 in. LCD Television
I deleted the coby software on my Coby MP300
Easiest solution that comes to mind is find someone with the same player. see if you load the drivers on your pc in a file if the you can load it as a new device and open it using drivers on your pc. Just a thought. then load the files back on the unit once you get access.
Mar 20, 2009 | Coby MP300 MP3 Player
Coby 224 Screen Slowly Fades to Dark and Back To Light
Usually if your getting it with the MENU then your connection is weak, are you going through a VCR or some other type of device besides directly to the tv? Try hooking unit directly to the tv. Besides that, its possible you could of messed with the settings, go to the menu, go to advanced and do a reset to make sure no settings were adjusted, the disk has to be out of the tray while you do the reset.
Jul 14, 2008 | Coby DVD-224 DVD Player
Televison & Video Logo
Top Coby Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
