SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
SOURCE: How do I tighten a Delta kitchen faucet that has
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
