Question about Radio Communications
If the radio is designed to use a two prong connector, then you will need to replace it with the same type. Generally, one prong is for the mic and the other is the speaker. There is usually a common ground on one of them and possibly the push to talk on the mic prong.
You shouldn't have much trouble finding a two prong replacement mic, eBay has many for most radios.
Posted on Sep 24, 2019
SOURCE: need to find ports to connect headset for skype
nerdy :( it should plug into the back .. several com ports one will be for audio with your sound card
Posted on Dec 06, 2008
SOURCE: power supply jack broke of laptop and am haveing a
Here is the link for some take your pick. Hope this helps, don't forget to rate.
http://www.nextag.com/ac-adapter-compaq-armada-e500/compare-html?nxtg=8f680a1c052e-5334EACDF784D28A
Posted on Feb 28, 2009
SOURCE: External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Posted on Jun 02, 2009
SOURCE: HP pavilion Webcam video sound barely audible desite use of mike/headset -
Are you running Xp or vista?
Posted on Jul 09, 2009
Jul 29, 2014 | Plantronics Radio Communications
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
Jun 22, 2011 | Plantronics M175 Headset
Aug 19, 2010 | Plantronics DSP-400 Headset
May 21, 2010 | Skull Candy Icon Headset
Jun 02, 2009 | Dell Inspiron 9300 Notebook
May 23, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Apr 09, 2009 | Jabra Bluetooth Headset with Adjustable...
Apr 11, 2008 | Palm Treo 755p Smartphone
Jan 27, 2008 | Palm Treo 755p Smartphone
117 people viewed this question
