Question about Bernina Sewing Machines
My bernina 830 shows a message saying "Memory Pool empty. CMsgMSSSet - FATAL ERROR! What does this mean?
Posted by Tracy Uhler on
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
Anonymous
  • 52 Answers
SOURCE: Top cover on my Bernina 830 is crooked
there are two screws on the top one by the bobbin winder and the other by the take up lever, you should be able to adjust it from there
Posted on Jul 07, 2009
Anonymous
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
elizebeth900
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
Rick Beament
  • 166 Answers
SOURCE: I need a Bernina 830 condenser
Do you mean the multi-part condenser that's used across the motor windings, or the one in the foot controller ?
Posted on Oct 30, 2011
How to remove the top cover of Bernina 830. My machine keeps telling me to rethread. It stitches about 10 stitches then stops
Which Bernina 830 are you referring to? (Yeah, it was crazy of Bernina to use the same numbers to identify different models...). There is the old Bernina 830 Record and the new computerized Bernina 830.
Have you tried rethreading the machine? If so, be sure to ALWAYS RAISE the presser foot. Verify the thread path is correct.
Apr 10, 2018 | Bernina Sewing Machines
Tip
Bernina 530 through 830 Record Oiling Diagram
Photo shows location of oil holes for Bernina 530-830 Records.
on Apr 03, 2015 | Bernina Sewing Machines
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Oct 19, 2015 | Bernina Sewing Machines
I have a Bernina 830 and it is locked with error message shown on p. 178 of the manual. Explanation is incorrect needle for the stitch plate selected. I have a Bernina 80 universal needle, the...
I don't have a good answer for you but I would remove both needle and plate, turn off and unplug machine for 10 minutes, replace needle and plate and 'reboot' the machine by turning it on and see if that clears any corrupted memory.
Dec 13, 2013 | Sewing Machines
Oct 28, 2011 | Bernina Artista 180
Bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Aug 27, 2009 | Bernina Sewing Machines
Sewing Machines Logo
163 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
