Dorian Davies Posted on Sep 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SONY MCH EX10AV ALL LIGHTS UP ALL CONTROLS WORK BUT NO OUTPUT ON ANY SPEKER CONNECTION ANY HELP PLEASE
Franco Dosil
Level 3:
Top Expert:
  • Sony Master 10,542 Answers
  • Posted on Sep 30, 2019
Franco Dosil
Sony Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378647
Points
178965
Hi Dorian Davies, as you comment, you would have problems at the speaker output stage
Try disconnecting it from the power outlet wait 15 minutes, reconnect it and see if it is corrected
If it does not you should look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Dorian Davies, por lo que comentas, tendrias problemas en la etapa de salida de parlantes
Prueba desconectarlo del toma corriente esperar 15 minutos, volver a conectarlo y ver si se corrige
Si no lo hace deberas buscar un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
I have a Sony music system mch rv6 problem is not a turn powering on and power bottom light is on please help me
There could be several reasons why your Sony music system is not turning on. Here are a few things you can try:
  1. Check the power source: Make sure that the power source is properly connected and that there is electricity flowing through it.
  2. Check the power cord: If the power source is connected, then the problem may be with the power cord. Try using a different power cord to see if it makes a difference.
  3. Check the fuse: If the power cord is working properly, then the problem may be with the fuse. Locate the fuse in the system and replace it if it's blown.
  4. Reset the system: If the above steps don't work, try resetting the system. To do this, unplug the power cord from the wall outlet, wait for a few minutes, and then plug it back in.
  5. Contact Sony Support: If none of these steps solve the issue, it may be a hardware problem. In this case, you may need to contact Sony Support for further assistance. They can guide you through the next steps, which may include repair or replacement of the system.
Please note that these are general troubleshooting steps, and the exact steps you need to take may vary depending on your specific system model.
Sony mch -gn1200d all the keys are not working.
Try connecting it a USB keyboard. If works, you should repair your keyboard. If won't work, it's a softwre related issue and you should post a new question, explaining the situation so someone might help you.
Can i connect to subwoofer to sony hi-fi minisystem MCH-RV888D
im not seeing any records on sonys site for your model, but, if you have no manual, and can find no approrpiate output- you CAN run subwoofers off the front speaker terminals IF you do it right. you will need a subwoofer with speaker level input and output, with an internal crossover.
How to hook the 3490 to get 4 ohms
Hello
The output impedence of the amp is 8 Ohms. It can also be connected to a 4 Ohms speaker, but the reted output will be higher than specifed, and the sound quality will be reduced. You cant get an putput impedece to this amp by no means, as its' output is desigend to match 8 Ohms/channel. If you have only spekers with 4ohms impedence, connect two of the in serieal connection, so that, they together will reach a resultant impedence of 4Ohms. Similarly connect an other two spekers in series to the other channel too. OK.
Can i connect spekers to tv without any sterio sisteem
Most of the Sony TVs have a sound output less that 4W or so. If you connect an external speaker directly, sthe speaker shoud match both in impedence and watts, to the internal speaker fitted inside the tv, otherwise the audio output ic inside the tv can get damaged.
You can connect the earphone output of the tv, if any provided on your tv, to the aux; input of your stereo. There is no trouble.
1helpful
Sony k530i mobile sound low
its a technical problem so plese change the speker
2answers
Were can I get the output to input cable from dvd to the speker sc36ht
the audio output of your DVD had to be connected to the audio input of your amplifier for the speaker to work
2answers
I can switch the radio on but the spekers do not come on ( the red light on the speakers dont turn green ) and there is no sound either from playing a CD or the tuner ???? all the plugs are connected -- it...
hi dear
your output aduio ic or transistor is damaged.or the problem is in the power supply.have a tech look at your set if you are not a tech.good luck
Red light 2
Probably not, as i said there are no user serviceable parts inside this unit. If the units worth it to ya take it in to be estimated. Good Luck
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
