Question about RC Toys
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
Posted by gmorales13 on
Anonymous
    New Friend:
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Posted on Dec 30, 2009
Anonymous
    New Friend:
Www.ujtoys.com
Posted on Mar 07, 2010
Anonymous
    New Friend:
If you are looking for replacement parts for Yiboo helicopters try ujtoys.com
Posted on Mar 02, 2010
Anonymous
    New Friend:
I went back to the mall where the guys sell the copters, but he did not have the pice i needed, but he had a huge box of broken helicopters. He told me to come back in a couple days and see what he had. I have the smaller UH-60 and the second blade shaft broke.
Posted on Jan 02, 2010
Anonymous
    New Friend:
Did we all get one of these toys from our wifes? I'm having a blast with my Ch-47, she also bought me a cobra that has taken a hell of a licking and is still ticking. the Ch-47 is a lot easier to control but they are both fun as hell.
Posted on Jan 01, 2010
Anonymous
Yibootoys.com has parts--they say
Posted on Oct 07, 2009
Anonymous
    New Friend:
Call me at 6302030082 i sell all replacement blades
Posted on Feb 22, 2010
Anonymous
Yiboo site is down and I think they are out of business. I heard the site only sold bulk/wholesale anyhow. Let me know if you find parts, I need some for my apachee
Posted on Jan 06, 2010
Anonymous
    New Friend:
I am looking for the same thing, i think. Can't find one. yiboo toys doesn't have the one I need.
Posted on Dec 29, 2009
The blade is wobbling on my Fleetwood meat slicer EF12 Slices look like waves.
check that the problem is not from the way the blade is mounted on the shaft
any thing between the blade and the backing hub of the shaft will make the blade wobble so check for burrs , bad fitting parts or the like at the blade center
new bearings , shaft and hub are new but is the hub on the shaft straight
Dec 17, 2015 | Home
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
Why does my blade to my dealt D28770keep walking its self out
Possible causes:
- Tires: If the tire(s) on the front or rear pulleys are worn, torn or have chuncks out of them, the blade can slip off.
- Pulley(s) out of line: If either or both pulleys are out of alignment the blade will work it's way off. This could be caused by a worn pulley hub; a worn or broken pulley axel; or worn, broken or frozen bearings where the axels turn. On the drive pulley this could include the bearings on the drive shaft or the boss where the bearings fit into.
- Blade: If there are any kinks or slight bends in the metal they could cause the blade to work off the pulley.
Mar 05, 2012 | Dewalt Saws
The blade on my Delta Model 36-075 miter saw spins freely - motor works fine - i disassembled down to the gear drive - the gear appears to be fine no missing teeth or obvious damage. Does the inner shaft...
hi, on your Delta saw shaft has two flanges which one goes in front of the blade and the other behind the blade. These flanges have two flat spots in the center of it which over the shaft, the blade has the same cut out so you need to check your shaft, flanges and blade to make sure they are all locking on the shaft. Do not forget to unplug the saw before you do any work.
Feb 09, 2018 | Delta Saws
I have a Homelite Z830SB Brushcutter. I use it with the blade attached rather than the line, for cutting. It starts fine, but it does not engage (i.e. the shaft does not spin...so there is no rotation in...
the inner shaft could have broken, which is the case a lot when using the blade vs the string remove the shaft from the motor, and spin the inner rod and see if the blade turns, if it does check the end of the rod and see if its damaged in anyway , if the blade doesn't spin, the shaft has broken and will need replacement
Jul 03, 2011 | Homelite Garden
Can the fan blade be easily remove on an Haier model HWR08XC1-T? I see a set screw on the fan, but there's no room to work and then remove. Sounds like a bushing is broken. Wobbles when running. Lot of...
Check and make sure the set screw is tight. Sometimes the screw will loosen and cause the problem you are describing.
However, to get the blade off - take out the set screw - spray some WD-40 in the hole - getting as much on in the hole (and on the shaft) as possible. Work the blade on the motor shaft (use a crescent to turn the shaft within the hub of the blade) and it should slide off the shaft.
If the blade is rusted on the shaft - do the above - but let it sit (with WD-40 on it) for awhile, i.e. several hours or even overnight if possible.
Note: sometimes there is a little disassembly (of the unit) you have to do to work the blade out.
Jun 07, 2011 | Haier HWR08XC1 Thru-Wall/Window Air...
I have an old GE Weathertron which still works (except I need a new fan). The unit is about 30 years old, but some goob from Dave's H & AC screwed it up and they had to send a new guy (who...
Use sandpaper to sand the motor shaft.
Then,
Lots of WD40 on the shaft and hub. Wait for it to penetrate.
Then hold the shaft with pliers between the hub and the motor and twist the fan blade right and lft to loosen it.
Try and pull it off.
If that does not work you will need a blade pulling tool.
May 25, 2011 | GE Heating & Cooling
Yiboo UJ 378 Helicopter only spins in circles. Tryed the adjustment on the controller. Has anyone else had this same problem? Has done this since I took it out of the box.
what a piece of ****. do not buy this. if u need a replacement part, the cost for handeling is usuall 2 times the price of the part.. beware and stay away from Uj Toys.
Jan 22, 2011 | Toys
How do you remove and replace the main rotor on the Havoc Stinger? I wasn't able to find a replacement blade for this specific model. Will the replacement blade for the Havoc heli work. Mine is clear not...
I just experience breaking my 1st main rotor and replaced it.
What you need are a pair of needle nose pliers and a hair dryer.
Put the hair dryer on "HOT" and blow on the rotor plastic shaft for
about 1 minute. Then take the needle nose pliers, lightly clamp
them on the plastic shaft and lift. It should slide off the metal shaft.
Next I took the hair dryer again and heated the replacement rotor
shaft for about 1 minute and pushed in on the metal shaft with my fingers.
Hope this helps.
Dec 25, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Aug 15, 2008 | Lasko 3723 Floor / Box Fan
Toys Logo
4,257 people viewed this question
Top RC Toys Experts
Tom Chichester
 Mikey
Mikey
ray gallant
Are you a RC Toy Expert? Answer questions, earn points and help others
