SOURCE: Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
SOURCE: Won't burn CD-r or DVD-R
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
I have the same unit. Similar problem but mine does not erase the disc. It says disc error on almost all dvd that are store bought and kicks them out. Will play almost all of the ones I recorded on it and finalized. I must let a disc in it at all times or door will not open. Lots of bad stuff on the net about this unit. It is a lemon! Mine is out of warranty and sony wants $175 to fix. Saw some blogs where it was serviced 3 times and still not right. Buy a new one before investing in the unit you have as there are many gremlins in it! Sorry I cannot offer specific help but this is where I am at!!
SOURCE: MDS-JE320
The loading mechanism needs to be repaired or replaced. This is a common fault. Unfortunately, this is not a really cheap fix. Usually the loading carriage needs to be replaced at a cost of about $40 or so/
Dan
SOURCE: same problem "movie recording disabled"
Scott,
Since this is a new camera, nothing was changed as far as the disc, it should work, has it been switched to "still" for photos, that's the message that comes up when you change it. You shouldn't have to finalize the disc before you shut off the camera, try starting it with another disc then shut it off replace it with your baptism disc and try to preview the video, if it shows you should be able to aad to it or then finalize it.
randy320sgi
