Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Does my hotpoint washing machine aquarius wd64 have a filter
Posted by barbandcolin on
Anonymous
    Problem Solver:
  • 5 Answers
If your hotpoint has no obvious filter ( small flap on front ) its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.
pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully andd make sure its all back together as before.
Not easy but the blocked filter causes so many hotpoint issues. Its a pain the way they have built it inside the machine rather than making it user friendly.
Posted on Sep 17, 2009
sharky69x
    Habit-Forming:
  • 13 Answers
Yes at the bottom of machine at the backend ... remove back panel at bottom back of machine and you will see a black sump hose connected to bottom of tub ... remove this and filter is in there ...
Posted on Sep 15, 2009
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: where is the filter on
If you remove the lower rear panel, you will see a large black hose fastened to the bottom of the tub, remove hose from tub and you will find filter in there..
Be careful as there will be water in there.
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Where can I locate the tumble dryer condenser and fluff filter for my hotpoint Aquarius extra WD64
from hotpoint web page spares
from you local hotpoint service agent spares section
Jan 28, 2017 | Hotpoint Washing Machines
Hotpoint aquarius wd64 red light not coming on , have checked the plug & fuse , Changed motor brushes that were shot ,still nothing , any ideas??
Sounds as though the door switch is playing up, try giving the door an extra push when its closed, if this does not work then you may need to replace the switch. This is not uncommon for these machines
Jan 25, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
How does the powder tray come out for cleaning on a Hotpoint aquarius WD64 washer dryer please ?
there is a tab in the mid section between the two sections for the softener. You need to push the tab down at the back you should feel it go down then gentle push in slightly then pull out.
Hopr this helps
Sep 05, 2010 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Sep 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer
Go to:
www.hotpoint .co.uk
Click on After sales, then on download user instruction books, put in you model number, and down load to your computer, or your printer.
Problem solved.
Plz rate my solution.
thanks, and merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Where is the filter on hotpoint aquarius wd64
Thanks.
Dec 15, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
