Baby Gear Logo
Jenny Pugh Posted on Sep 15, 2009
Have three grandsons and only two seats in rear with shoulder and lap seat belts. Are there any child booster seats can be used with lap only restraint?
Anonymous
Level 1:
  • Contributor 164 Answers
  • Posted on Sep 24, 2009
Anonymous
Contributor
Level 1:
Answers
164
Questions
0
Helped
136221
Points
56
Yes there is wal mart has one for $18.00 called
Cosco - Ambassador No-Back Booster Car Seat
Can you use a lap belt only with this booster seat?
  • Yes you can. The belt goes between the front and rear sets of arms on the booster seat. It is always advised to use a shoulder strap with it but you need a clip to bring the direction of the top of the shoulder strap [seat belt] to avoid neck (throat) impact. If this is not possible at the moment then run the shoulder strap behind the child and the lap belt portion over their lap, between the two sets of arms, as they sit in the seat. Then get a seat belt locking clip soon. You can get them anywhere on the net and at your local department stores as well for $7 or so. Like this one here. http://cheapboostercarseatcheapprice.tk/cheappriceoffer/graco-seatbelt-locking-clip-B0002ADQOU
Regards, Tony
3helpful
In order to change from the toddler seat to the booster for a child over 40 lbs, what do I do?? does the seat just become attached to the car by the seat belt? does it need to be attached by other...
please feel free to call at 1-800-544-1108 and they can send you a manual in case you dont have it.
*To convert the car seat into a booster seat, turn the car seat over and remove the pin that holds the base in place. tHEN REMOVE THE BELTS AND THE BUCKLE.
*To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused
PLEASE RATE MY HELP :)
4helpful
Center rear seat does not have a shoulder/lap seat belt
You should be able to go to the dealer and buy the center lap belts and can install them without having to by the seat just call your loacal dealer they can tell you how much thy are, less expensive than the seat.
10helpful
How do you convert it from a car seat to a booster seat?
Take the base off if it has one, either clips, screws, or a metal rod holding it on. Take the belts out. They should slide off the clip at the back of the seat, then unthread belts from buckles. The buckle/strap between the legs usually has a metal keeper below the seat. To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused.
When installing the forward facing booster seat do you not hook in any of latches to the seat? We have model #22-757-MRC. My children are over 40 inches so I am swithching them to the booster seat. My...
your child's weight and the lap & shoulder belt hold the seat in place.  Run the lap part across your child's lap and the shoulder part should cross your child's chest and not cross his/her neck.  There should be some slots on the side near the top to allow some adjustment of the shoulder strap.
Sep 06, 2009 • Baby Gear
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
2helpful
Need a car seat manual
Types of car safety seats at a glance
The chart below is a quick guide on where to start your search. However, it’s important to read more about the features and how to use your car safety seat.
Age Type of Seat General Guideline Infants Infant seats and rear-facing convertible seats All infants should always ride rear-facing until they are at least 1 year of age and weigh at least 20 pounds. Toddlers/Preschoolers Convertible seats It is best to ride rear-facing as long as possible. Children 1 year of age and at least 20 pounds can ride forward-facing. School-aged children Booster seats Booster seats are for older children who have outgrown their forward-facing car safety seats. Children should stay in a booster seat until adult belts fit correctly (usually when a child reaches about 4' 9" in height and is between 8 and 12 years of age). Older children Seat belts Children who have outgrown their booster seats should ride in a lap and shoulder belt in the back seat until 13 years of age.
5answers
Child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 • Baby Gear
2answers
Booster
Remove straps and belt across the lap!
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
