Question about Freezers
Where can I purchase the switches for my Igloo countertop icemaker 102 ST?
Posted by Glen Richards on
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Why is my igloo portable ice maker hot?
The heat that is being removed from within the unit has to be extracted towards the outside. A lot of times the condenser coils are on the surface just underneath the exterior panels.
Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Countertop Icemaker is only making a few thin cubes every hour , maybe buildup from bad water ! What can i pour in it to clean ?
I would switch off the power, disconnect water and keep it so for a few hours. While power off, clean whatever visible build up you find. And make sure you shut the water valve before disconnecting unless you want another project! After a few hours connect water and power and wait until ice made. Goodluck.
Apr 05, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Freezers Logo
148 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
