Most of the time when your plugged into the pc it will charge see if this is true for your player if so leave it on the the pc for a few hours also drain the battery fully then charge for a few hours
The Sylvania SMP2012 charges fully in under 15 minutes on a regular USB port. Sometimes it's much quicker.
When the device is charging, both the red and green LEDs are lit (not flashing). When the device is fully charged, the green LED turns off, and only the red LED is on.
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
iTunes uses an m4a audio format which is not supported by your player. Convert the songs to mp3 and try again. You don't need drivers just drag and drop or copy and paste.
let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
