Frigidaire Gallery - 5 years old Water is spraying down the refrigerator side, but the water filter.
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
SOURCE: Frigidaire Gallery Series M# GLHS36EESB5
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
SOURCE: Frigidaire Gallery Washer GLWS1233 leaks
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
If the washer leaks only during the fill cycle, check these:
During drain and spin only
A
washer that leaks only during the spin cycle often has a leak in the
main drain hose. Inspect the entire hose and correct any problem you
find. Alternatively, the steel or plastic outer tubs can rust, split,
or be punctured. This may be most visible during large loads and high
water levels. If this happens, you may have to replace the entire outer
tub--but that may not be an economical repair to make. Consult a
qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
P.S. – I would greatly appreciate a FixYa!
rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
r further details.
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
SOURCE: frigidaire gallery pro series model frs26zsh water
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
