Question about Blomberg Refrigerators
My Blomberg freezer seems to be running almost continuously
Posted by Christine Miller on
Steve F
  • 1,360 Answers
Can be 2 things. If its over freezing, its likely the thermostat has jammed closed and continually causing the compressor to keep running. This will make the freezer get too cold and over freeze. If its not icing up and not getting cold, I would say its lost its gas charge. The compressor is continually running, trying to get down to temperature.
Posted on Sep 23, 2019
My Blomberg reezer-bottom refrigerator is only 1 year old but the freezer door is bowing and won't seal properly. Why? How can it be fixed?
maybe a good kick to the door or is it still under warranty? Give the dealer a call and tell em to come round and fix it..
Jul 11, 2018 | Blomberg Refrigerators
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
How do l set the temperature control on my new Blomberg built in freezer?
get the technicians back for a warranty check or get a refund on a faulty product
Nov 23, 2017 | Refrigerators
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Dead Washing machine
seems issue with the control panel. try unpluge the unit and pluge back after 10 min and chk.
Aug 12, 2008 | Washing Machines
Refrigerators Logo
114 people viewed this question
Top Blomberg Refrigerators Experts
Marvin
Marvin
john h
ray gallant
Are you a Blomberg Refrigerator Expert? Answer questions, earn points and help others
