I need p1622 code image - Office Equipment & Supplies
Posted by Suresh Coorg on
I have 2014 jeep compass and it throwing a code p1622??? any ideas on what it means???
p1622 is a manufactures test code cylinder select if the check engine warning is not on dont worry about it
Apr 10, 2018 | Jeep Cars & Trucks
MY NISSAN YD25 IS HAVING SERIOUS ENGINE VIBRATION AND THE DIAGNISTIC MACHINE IS SHOWING ERROR P1622 INJADJVALUDRST. WHAT COULD BE THE PROBLEM
Did you replace the ECM? The ECM has lost the reference information for the injectors and it must be reprogrammed. Unless you have the proper console for this you have to take it into a dealer.
Feb 26, 2018 | Nissan Cars & Trucks
How to fix Nissan Navara fault code p1622 injector adjustment value
PDF]check intermittent incident - Control System
controlsystem.pl/manual/NAVARA_D40_OVERVIEW_MANUAL.pdf
Fuel Injection Timing Control System .......... .......... 20 ... Fuel Pump Learning Value Clearing .......... ........... 24. Injector Adjustment Value Registration . ... Diagnostic Trouble Code (DTC) . ...... DTC P1622 INJECTOR ADJUSTMENT VALUE .... 271.
Nov 07, 2015 | Nissan Cars & Trucks
How do I fix fault code 1622 Nissan Navara
P1622 - Engine-Codes.com
www.engine-codes.com/p1622.html
Possible Causes and Repair Information for P1622 code. Learn what does P1622means? P1622 Immobilizer ID Does Not Match.
Fault code p1622 nissan navara d40 - Fixya
www.fixya.com/cars/t17579043-fault_code_p1622_nissan_navara_d40
Apr 8, 2013 - This fault code comes up on scan guage. Would any one know what it ... dealer only to reset factory immobiliser ... The best, and in fact the only
My car is Nissan np300 2011 and is showing the code p1622 inj adj val unregistered this was after fitting new injectors what can that be
Sometimes (depending on the vehicle) the light will not go out by itself (after fixing the problem). If so, _must_ be reset (''cleared'') by a code reader tool. It is also possible you still have a different problem. Only the service book can tell you meaning of the codes. (Not a book you can buy at an auto parts store, but a dealer service manual for that specific vehicle).
Oct 17, 2014 | Nissan Pickup Cars & Trucks
My Nissan np300 2011 is showing code p1622 inj adj val unregistered what is the problem
First of all. Changing injectors about just because the power of your vehicle is low, is highly unlikely to solve your problem. Like trying for a grand slam when blindfolded.
Second of all it is highly probable that unless your new injectors were purchased from the dealer for your car specifically, that you got similar injectors of a different impedance, or perhaps entirely different injectors, this would easily explain your CEL code because the engine computer has no idea what to do with the injectors you installed.
My advice would be to go back to the original injectors, and try to solve your low power issue another way like checking the O2 sensor, or making sure you TPS is properly adjusted.
What is map cooling control circuit electrical P1622
A code with P1XXX is brand specific so check out this web site:
http://www.obd-codes.com/trouble_codes/ this should tell you some possible reasons why you have pulled this code for your brand of vehicle.
Jun 26, 2014 | 1999 BMW Z3
II have a 2002 Saab 95 Linear that has a DTC of P1622. What does this code mean?
Check all connections to the TRIONIC MODULE and the ECU.
Aug 01, 2010 | 2002 Saab 9-5
Marvin
Marvin
