Question about Samsung YP-Z5 MP3 Player
Apple Ipod Touch is disabled because i forgot my password and when it tells me to connect it to itunes i connect it and the device doesnt come up on itunes PLEASE HELP ME!
Anonymous
  • 3 Answers
My PC does not detedcted the YP-Z5 player
Posted on Sep 15, 2009
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
2helpful
Hi my 16gb apple ipod doesnt work someone try to open my ipod by using wrong password so it tells ipod is disabled connect to itunes how can i solve this problem could u help me
You should connect it to your computer, I've actually never had this problem but I guess once your on iTunes it would reset the password and you could entry it normally. If it doesnt you could try to connect it to iTunes and then hitting the restore button. This will erase all your data and the put the latest back up you had on your computer in your iPod. Normally the information in the games and so would be erased. But contacts, notes and other apple-related apps will remain un-touched.
My ipod is disabled because I forgot the password and when I connect to itunes to restore it, it tells me that ther is an error. How do I fix this?
go to http://support.apple.com/kb/ht1808 here you have instructions for manually restoring resetting your touch
You can unlock your IPOD Touch passcode or password by following these simple steps.
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your iTunes
3helpful
Apple Ipod Is disabled
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
21helpful
3answers
Forgot my ipod touch password and now its disabled
Connect to iTunes, go to the settings menu of your iPod (click on the picture of your ipod on the bar on the side.) Then click "restore my ipod's settings," or something similar to that. You will have to re-sync your ipod, but your password will be removed. hope it helps
The ipod touch won't let mei into my music page?
There is no method to recover the password or bypass it. Apple very clearly says this in their manual. Now that we have this cleared.
You will need to restore the ipod. I know this sucks but unfortunately this is the only way to start using it again.
To restore iPod.
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3. Open iTunes. It will show up as a device. 4. Select iPod touch in the iTunes sidebar and click the Summary tab. You will see the details of your device along with link to restore ipod.
click this 'Restore' button. You will get a warning that it will erase all data, settings and music. Click Yes. Follow onscreen instructions.
It can take you upto 4 hours to restore your ipod again depending on the size of your data.
I forgot my password and no its been disabled
plug it into itunes and tell it to revert back.. in your ipod in itunes
41helpful
5answers
Ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
Samsung YP-Z5 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
