Question about Lexmark X4690 Wireless InkJet Printer
Only printing last page of all documents sometimes says printing but doesn't even print
Posted by sandra_danie on
bhadresh khatri
    Sergeant:
  • 191 Answers
Please your open the programmes and open the page
and give a control p comand and select to page and apply print
and s
econd time you go file menu in printer page setup is open
and even page select and setup ok
and third time you go my computer in printer open
and penter setup page setup and youyr printer select and apply.
ok
Posted on Sep 15, 2009
Trying to print a 15 page word document but the printer keeps printing only one page repeatedly even though i have clicked print all as well as pages 1-15
I've had similar issues and here's what I found was the quickest and easiest solution. Select, cut and paste the entire document into a new document with a different a name. Sometimes the document format gets corrupted while typing.
Aug 06, 2014 | Canon Pixma MG5220 InkJet Printer
Not printing document in its entirety; only certain paragraphs
Have you tried to install the printers drivers again???? Also, sometimes who ever wrote the piece, may not want the info printed and has blocked it???? Good Luck
Feb 05, 2013 | Kodak ESP C315 Wireless All-in-One Printer
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
I tried printing a document, and it printed all the pages except for the last page. I have tired to repeatedly print the last page and it will not print. The toner light is on, so does that mean I have...
hi,
first of all maybe your file has a problem. DO NOT CHANGE your toner. Try to print only last page, or copy the content of the last page in the new document and the print it. Sometimes the printer can not recognise some files correctly and that is the major problem
pifonski
Feb 18, 2011 | Brother HL 2140 Laser Printer
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
Because my Deskjet 932C wasn't printing at all, I downloaded a new driver for it from the HP site. Now it prints but prints only the top portion of a page -- sometimes about 1.5 inches, sometimes 3 inches,...
I would recommend uninstalling the installed driver from your system, disconnect the USB cable (if one is installed), reboot.
Once the system comes back up, turn off your anti-virus. Now install the printer driver again. Install the USB cable for the printer (if that's how you're connecting) and finish the install.
Re-enable your anti-virus.
Aug 29, 2009 | Office Equipment & Supplies
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
Lexmark X4690 Wireless InkJet Printer Logo
288 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
