The recent data is what is taking up space. so you need to go and remove some of the saved addresses that you no longer need.
If you have music and pictures saved as well then these will need to be deleted to increase the extended memory. The units only have 64Mb of memory to swap between RAM and card. so empty off some of the other things you have other than maps to increease space for Msap data.....
if you dont have saved data, then somewhere there is a corruption . in the mapping software I might suggest here that a GPS shop wherever you are touring should be able to help faster than through this forum .
pleae rate our help to keep FREE service online++++Thanks for using FIXYA
Does yours have a memory card slot on the right side? if so u can upgrade that memory card and transfer the info from the old to the new by putting the info on a computer with a card reader then putting the info from the computer to the new bigger memory card. i would get like more than double the current memory. cards are fairly cheap these days.
