Question about The Health & Beauty
Quingo Air 2 when i switch ignition on and press the wigwag controller there is a click then 8 flashes, motor volt error it happened when i reversed down a ramp and suddenly stopped.
Rob Hill
  • The Master
  • 1,414 Answers
Hi, okay can you confirm the controller colour ? is it black or chrome looking ?
Black, Normally a Curtis
http://www.fsip.biz/Documents/1212_12P.pdf
Chrome is a S Drive.
https://support.pgdt.com/Online-Diagnostics/Flash-Code-List/S-Drive-Flash-Codes
but as you say there are eight flashes make me think it is a S Drive.
They are repairable.
Regards
Rob
Posted on Sep 23, 2019
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Posted on Oct 25, 2007
Anonymous
  • 19 Answers
SOURCE: wont spin
may be lid problem
Posted on Nov 01, 2007
Anonymous
SOURCE: new 208 dodge charger with
To activate factory wigwags in a 2007/2008 Police Dodge Charger, connect pin 1 of the 24way upfitter connector found at the console (near the radio) to battery voltage -- the 47k series resistor is only required for MY2006.
That connection causes the VSIM module (located under the AM/FM radio) to send a CAN message to the FrontControlModule, where the front control module drives the headlights in the wigwag mode.
Pin 2 of the upfitter connector does the rear wigwags.
Some of the pinout of the 2008 upfitter connector from the VSIM to the console is different than 2006/2007 -- a Chrysler harness booboo for 2008.
Note that the VSIM (also known as PTIM) module is only on factory police Chargers -- civilian cars do not have this module.
Posted on Sep 09, 2008
Anonymous
  • 13 Answers
SOURCE: Treadmill won't slow down
if you look at the front roller. there will be a black device that has two wires. this is your speed sensor. Make sure it is facing the magnet on the roller.
Posted on Aug 10, 2009
Anonymous
SOURCE: 2003 mitsubishi convertible top won't work
There is a switch located just above the left rear brake light, peal bake the trunk liner and you will see it. It says manual/auto, switch it back to auto and the top should work. You probably just bumped it as my brother in law did, no convertible for over a year...good thing he lives in Seattle.
Posted on Aug 16, 2009
Tip
How a furnace operates and what you can do to troubleshoot.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed through the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Many newer furnaces have a diagnostic light viewed through a small window in either the top panel or bottom panel. If you remove a panel to see it, you may erase the code. If that happens, tape down the door safety switch and cycle the furnace with the panel off until the code appears again. Find the wiring diagram that is glued on one of the panels. There will be a diagnostic or error code chart that will give you a starting point where to look based upon the number of blinks the circuit board flashes.
Check out other tips at www.chandlerrepair.com.
on Dec 16, 2009 | Heating & Cooling
Invacare HMV 220 3 wheel scooter. Good battery, Why won't it go?
hi, the clicking sounds like the brake and if that's the case your throttle pot etc is working okay. check the connections from the controller to the motor, putting 12v on the motor does not prove it's okay resistance wise for the controller, it looking for about 0.2 to 1.5 ohms...
if that all proves okay then i look at the controller ...what is the name of the mobility scooter ?
Regards
Rob
Dec 31, 2015 | Health & Beauty
2009 ultra classic / check engine lite stays on / cruise won't set / oil pressure gauge is low at idle but goes over 32 when rev'ed. 12100 miles. killed once and Black smoke seemed to come from air...
Revove power comander& see w/ happens...I have a 09 flh also I installed a TFI fuler.. wow test Engine light being on. That is the sign there is a Code that is stored. This may help you.
Harley iagnostic Codes
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word ¡°diag¡± should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the ¡°t¡± looks more like a ¡°¨\¡± )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC¡¯s the code will be displayed or the word ¡°none¡± will appear if there are no DTC¡¯s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC¡¯s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC¡¯s again by repeating steps 1 to 3 If the code is current it will reappear.
4 ¨C Press and release the odometer reset button to continue to the next module.
5 ¨C Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No C...[Message truncated]
Aug 15, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a problem with a Baxter OV300g Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Check to see if your draft inducer (exhaust fan) is running, if it is then you could have a dirty/bad air switch, the component with the small black hose running to it and the two wires on the face. To check an air switch using a multi-meter set it to 40 VAC and place a lead on each terminal, if you are getting a voltage reading over 1 volt, replace the air switch, if you have zero volts, the air switch is closed and working. Aside from a bad exhaust motor or air switch there could be many things causing that error.
Jul 30, 2011 | Baxter OV300E Stainless Steel Electric...
Central heat not working right
You may just have a dirty air filter or your furnace may be flashing an error code that could help you. Look for a small viewing port that looks into the cabinet of the furnace. Look for a blinking light. Count the blinks and then find the wiring diagram pasted to one of the panels. On the diagram it will have a diagnostic chart where you can look up the error code. Read on for some basic info that may help you.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
Feb 08, 2010 | Goodman GMS90703BXA Heater
Igniter does not turn on
need more info....Remove the front panel and look for a sticker that will tell you what the Diagnostic flash codes are...3 . 4 . 5....etc...I service many funaces and cant memorize all the codes..lol...we always need the \manual....What does the furnace do??...Turn the power off (after you observe the code)...then turn it back on with a call for heat....What happens????The exhaust fan starts......then the ignitor starts glowing....etc.////this info is more important than flashing codes
Oct 31, 2009 | Goodman GMS90703BXA Heater
Won't egnite, light is flashing 3 times.
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light). 3 blinks may be a restriction in either the air intake, exhaust pipe, condensate hoses air filter or a bad pressure switch or connection.
Oct 18, 2009 | Coleman Heating & Cooling
2004 silverado with dual manual temperature controls. Will not blow hot air out of driver side vents.
could be your controller or temp mix door
1. Gain access to the air temperature motor for circuit testing. There are 5 wires at the motor.
2. The Brown wire is ignition power.
3. The Yellow wire is a ground at all times, through the control head.
4. The Light Blue/Black wire carries a 5-volt reference from the control head to the temperature motor.
5. The Light Blue wire is the feedback circuit to the control head and should measure between about 1 volt (cold) and 4 volts (hot). This feedback circuit operates similarly to a Throttle Position Sensor (TPS).
6. The Dark Blue wire is the motor control circuit sent from the control head.
7. When the control head sends out 5 volts on this wire, the motor moves towards hot.
8. When the control head sends out 0 volts, the motor moves towards cold.
9. When the temperature motor reaches the correct position (as measured by the feedback voltage on the Light Blue wire), the control head sends out 2.5 volts. This voltage signals the temperature motor to STOP and hold its present position.
10. Check for correct operation of these voltages.
11. In some cases, the air temperature door doesn't fit correctly in the plenum and will cause the air temperature motor to travel too far. This will cause the control head to become confused and operate erratically.
Oct 11, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
How do i get the trouble codes off a 1989 mazda mpv?
http://img178.imageshack.us/img178/3331/obdikx3.jpg
The above link is to a diagram of your ALDL connector, all you need is a paper clip, straighten out the paper clip and insert one end into the diagnostic test pin and one in the system ground pin (terminals A & B).
Then put the key in the ignition and turn it to the on position but DO NOT start the engine. You will then see the check engine light flash. It will initially start by flashing once, then a pause and then flash twice and it will repeat this three times. That flash sequence indicates 12, which just means the system is operating. Its the flash sequences after that that will give you the code if any are stored.
For instance if it flashes twice, then pauses, then flashes four times, thats code 24. So any flash sequence you get after the initial 12 (flash once, pause, flash twice) you need write those down. Below is a list of diagnostic codes to tell you what the codes mean.
Code 12
1 flash, pause, 2 flashes
Diagnostic: This Code will flash whenever the diagnostic terminal is grounded with the ignition switch turned on and the engine is not running.
Code 13
1 flash, pause 3 flashes
Oxygen sensor voltage stays between 0.35 and 0.55 volts for 30 seconds when the TPS signal was above 0.55 volts. The engine had been running for at least 40 seconds with an engine temperature above 110° F.
Code 14
1 flash, pause, 4 flashes
Coolant temperature sensor signal indicates a temperature of over 284° F for 4 seconds after the engine had been running for at least 10 secondsCoolant Sensor Circuit (high temperature) If the engine is experiencing overheating problems, have those fixed before continuing. Check all wiring and connectors associated with the coolant temperature sensor. Replace the Coolant temperature sensor.
Code 15
1 flash, pause, 5 flashes
Coolant Sensor Circuit (low temperature) Coolant temperature sensor signal indicates a temperature colder than -36° F for at least 4 seconds after the engine had been running for 2 seconds. See above, then check wiring connections at the ECM
Code 16
1 flash, pause, 6 flashes
Charging system voltage was either below 9 volts or above 17 volts for 10 seconds. System High Voltage If the voltage is above 17.1 volts for more than 2 seconds, the Service Engine Soon light will illuminate. Have the charging system checked.
Code 17
1 flash, pause, 7 flashes
PCM did not detect any spark reference pulses within 240 fuel control reference pulses (80 crank revolutions) while engine was running below 1200 RPM. Spark Reference Circuit.
Code 21
2 flashes, pause, 1 flash
Throttle Position Sensor, TPS voltage was above 0.8 volts for 5 seconds when engine was running and air flow was less than 15 gm/sec, or the TPS voltage was over 4.8 volts at any time.
Code 22
2 flashes, pause, 2 flashes
Throttle Position Sensor check TPS adjustment. Replace the TPS sensor. TPS voltage was under 0.2 volts for 4 seconds when the ignition was on. Check for a sticking, or mis-adjusted throttle position sensor.
Code 23
2 flashes, pause, 3 flashes
Inlet air temperature sensor signal showed an air temperature of -29° F for 4 seconds. Manifold Air Temperature. Check the MAT sensor, wiring, and connectors for a possible open circuit. replace the MAT sensor.
Code 24
2 flashes, pause, 4 flashes
Vehicle speed sensor signal showed less than 3 MPH for 2 seconds when engine speed was greater than 3000 RPM and transmission has not been in park or neutral for more than 4 seconds. Or vehicle speed goes from above 18 MPH to 0 in less than 2 seconds without applying brake. This code can only appear when the vehicle is in motion, if it appears when the car is not in motion, ignore it. Check ECM connections, any other problems should be diagnosed by a qualified mechanic.
Code 25
2 flashes, pause, 5 flashes
Inlet air temperature sensor signal showed an air temperature of over 218° F for 5 seconds when vehicle speed was greater than 35 MPH. Check the voltage between the MAT sensor and the ECM. voltage should be above 4 volts.
Code 26
2 flashes, pause, 6 flashes
Quad-Driver sense voltage shows a low voltage when battery voltage should be present, or if the sense voltage shows battery voltage when a low voltage should be present for at least 5 seconds when the engine was running. Have the car checked by a dealer.
Code 27
2 flashes, pause, 7 flashes
2nd gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 2nd or 4th gear switch was open when engine was first started. Gear switch Diagnosis Have the car checked by a dealer.
Code 28
2 flashes, pause, 8 flashes
3rd gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 3rd or 4th gear switch was open when engine was first started.
Code 29
2 flashes, pause, 9 flashes
4th gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 4th gear switch was open when engine was first started.
Code 31
3 flashes, pause, 1 flash
PRNDL indicates a gear other than park or neutral for 13 seconds for 3 consecutive startups when ignition was on, engine was off and vehicle speed was 0. Or the PRNDL status indicators (A, B, C, P) showed an incorrect combination of Lo and Hi for more than 10 seconds.
Check all connectors, and for a faulty switch.
Code 32
3 flashes, pause 2 flashes
EGR System Check vacuum hoses and connections for leaks and restrictions. Replace the EGR solenoid or valve.
Code 33
3 flashes, pause, 3 flashes
MAF Sensor Have the mass air flow sensor replaced.
Code 34
3 flashes, pause, 4 flashes
There was no MAF signal for over 4 seconds while engine was running. Check for loose or damaged air duct, misadjusted minimum idle speed and cacuum leaks. Inspect the MAF sensor and the electrical connections.
Code 38
3 flashes, pause, 8 flashes
The Torque Converter Clutch portion of the brake switch was open and caused the TCC to be inoperative, adjust OR replace switch.
Code 39
3 flashes, pause, 9 flashes
Torque Converter Clutch Check ECM connections, check for faulty Torque Conver Clutch solenoid.
Code 41
Cam sensor signal was not received by PCM for the last 5 seconds while engine was running. Check for faulty connections, or a faulty cam sensor. Maybe also indicate a problem with the vehicle's timing chain.
Code 42
4 flashes, pause, 2 flashes
The Electronic Spark Timing (EST) signal did not change when the ECM applied bypass voltage to the ignition module. Check for faulty connections, or a faulty ignition module.
Code 43
4 flashes, pause, 3 flashes
Knock sensor signal was either above 3.5 volts or below 1.5 volts for at least 20 seconds. Check for a faulty knock sensor, or Mem-Cal.
Code 44
4 flashes, pause, 4 flashes
Oxygen sensor voltage was under 0.25 volts for up to 4 1/2 minutes of closed loop operation, lean exhaust. Check the ECM wiring connections. Check for vacuum leaks at the hoses and intake manifold gasket.
Code 45
4 flashes, pause, 5 flashes
Oxygen sensor voltage was over 0.75 volts for 2 minutes in closed loop operation with a throttle angle between 0.6 and 1.9 volts. Rich exhaust. Check the evaporative charcoal canister and its components for the presence of fuel.
Code 46
4 flashes, pause, 6 flashes
Power Steering pressure switch Check for faulty connections, or a faulty switch.
Code 48
4 flashes, pause 8 flashes
Misfire Diagnosis. Check the ignition and fuel systems.
Code 51
5 flashes, pause, 1 flash
Prom or Mem-Cal Make sure the MEM-Cal or prom is properly installed in the ECM. Replace Mem-Cal or prom.
Code 52
5 flashes, pause, 2 flashes
Cal-Pak Check the Cal-Pak to insure properation. replace the Cal-Pak.
Code 54
5 flashes, pause, 4 flashes
EGR #2 solenoid was out of range for 6 of 8 tests. 55 EGR #3 solenoid was out of range for 3 of 5 tests.
Code 55
5 flashes, pause, 5 flashes
ECM Check for faulty connections. Replace the ECM.
Code 56
5 flashes, pause, 6 flashes
Quad-driver voltage was incorrect for 5 seconds on the circuit connected to QDM "B".
Code 57
5 flashes, pause, 7 flashes
Boost control solenoid did not open bypass valve causing engine torque to be too high.
Code 63
6 flashes, pause, 3 flashes
EGR flow was incorrect. EGR solenoid did not work properly. Have vehicle serviced by a dealer.
Code 64
6 flashes, pause, 4 flashes
Same as Code 63 EGR flow was incorrect. EGR solenoid did not work properly.
Code 65
6 flashes, pause, 5 flashes
Same as Code 63.
Dec 31, 2008 | 1989 Mazda MPV
Health & Beauty Logo
128 people viewed this question
Top The Health & Beauty Experts
Robert
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
