Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
thank you for returning back to me on this as long as you did accept the session i will be credited with the amount ok so dont worry about that all i am concerned with is helping out others i did it for 23 years in the military so now that i am retired i intent to do it here too ok best regards mike
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
SOURCE: freezer not freezing
sounds like a leak in the system if under 5 years call frigidaire if not get a whirlpool
SOURCE: Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Hi Mike,
You were very helpful last night. I did not reject your solution. My connection failed. When I logged back in, iverish picked up. I told him that I was working with you. He said to reconnect, and I would get you, but for some reason I was unable to reconnect. I do not know how payment works, but you should get paid for the help you gave me. What can I do to see that all is fair? I would give you a high rating.
Apparently, you must get mistreated frequently, and it must be frustrating.
Thanks for rejecting my solution even though it was the correct one. Hope the guy iverish who repairs cameras gave you a solution that was wrong and costs you a bunch of money!
