OKI C5500n Printer Logo
Question about OKI C5500n Printer
How I can fix error of OKI C5500 the msg on painel is 923 Fatal Error.
Posted by Flavio Santos Filho on
5 Related Answers
Anonymous
  • 136 Answers
SOURCE: fatal error 928 Oki C5500
Open the Unit Up, the Button on the Side opens the Printer. In the rear of the Printer you will notice the Element in the rear of the Printer.
It is usually hot. Well there is latches
as an Authorized Okidata Service Provider I believe these "TABS" should be the color of BLUE. release the tabs and the entire fuser come out just grab the handle that usually comes equipped with the fuser , it is usuallyon top just grap ir and lift it out. Install the New One and your Done.
Posted on Sep 13, 2009
Anonymous
  • 24 Answers
SOURCE: getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Posted on Jan 24, 2010
Anonymous
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Anonymous
  • 8197 Answers
SOURCE: oki c5500 paper jam.........cleared paper
To replace the fuser go to the link below.
http://www.laserquipt.com/support/idx/43/581/article/Fuser-Replacement-.html
Good Luck
Posted on Oct 20, 2010
hpprintermun
John Smith
  • 35 Answers
SOURCE: error 163 on oki c5500 printer
Call Printer Experts - 877-690-9305
Posted on Mar 28, 2018
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
3answers
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
6helpful
2answers
FATAL ERROR 923
923 - black image drum lock error
make sure the black drum is in correctly
make sure black toner is locked
reboot machine
1helpful
Getting error 142 fatal error
122 fatal error on c5500
Power Supply Fan Motor Error
When low-voltage PSU thermal error or a malfunction of fuser ventilation fan (PX713 only)/PSU cooling fan has been detected. Unplug the printer from the power source, wait one moniute, then plug unit back in and restart.
Seek attention of service person if restarting the printer does not correct the problem
29helpful
2answers
Fatal error 980 OKI C5500 printer
2answers
OKI C5900
we have the same problem but with Oki c5500
2helpful
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Top OKI Office Equipment & Supplies Experts
Clive
Clive
Gary
Gary
George Mclaughlin
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
