Hi I have Herman Kardon avr 20 switch goes on and after 2-3 seconds goes off.
Posted by Thabo Mothoa on
5 Related Answers
Anonymous
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
SOURCE: my center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Posted on Oct 07, 2009
Anonymous
  • 58 Answers
SOURCE: need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Posted on Oct 24, 2009
Kevin Braid
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
yammy_alf
wenceslao alfar
  • 666 Answers
SOURCE: hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Posted on Apr 06, 2010
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Harman kardon avr 151 stuck on tv speaker mode
Hi
Try this.
1. Press the front-panel Standby/On switch for more than three seconds to turn the AVR
off (the Power Indicator will turn amber).
2. Press and hold the front-panel Surround Modes button for at least 5 seconds until the
RESET message appears on the front-panel Message Display.
NOTE: After performing a processor reset, wait at least 1 minute before pressing any
Source Selector buttons.
Good Luck
Happy to help
Jan 04, 2014 | Harman Kardon Audio Players & Recorders
Avr 1610 turns on then goes into device sleep mode
Here is the manual and if you have anymore issues let me know.
Thanks,
Jason
Harman Kardon AVR 1610 Owner Manual System Settings Sleep Timer Processor...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Dec 29, 2013 | Harman Kardon AVR 1610
Can I connect 4 ohms speakers on the AVR 230? Thanks
Hello
Output impedence of 95% of Herman Kardon sets are desighed for 6 Ohms speaker. There is an output speaker sensor circutary it it which sense the impedence of the connected speaker. it is a built in feedback circuit and is ment for protection for both speakers and power amplifier section of the amp. If you connect a 4 Ohms speaker, the set will sense it and there is a chance to get it tripped as you increase the volume. Just connect and check. Advance the volume of the set very gently. If tripping occurs or it just cut off as soon as switch ON, never connect it again. OK.
Jul 27, 2011 | Harman Kardon AVR 230 Receiver
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
