Where is lodgenet card located - Computers & Internet
Posted by Thomas Johnson on
What tool do you need to open the back to replace batteries
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 06, 2014 | HD SUPPLY UNIVERSAL TV CLEAN REMOTE W/...
Lodgenet remote wont let me use volume of power off
Check an other setup code for your device. Some setup codes might work with certain functions. Select one setup code, which will give you maximum functionality.
Jun 03, 2012 | Televison & Video
I just purchased a 32 LC5DC and it came with a remote, not the original though and we cant get the T.V to pick up all of our channels--Can you do this without the original remote?
if you can acsess the tv menu you can obtain a new channel search i would take the tv back if under garentee still if you can all ways but a free view box
Dec 20, 2010 | LG 32LC5DC 32 in. LCD HDTV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Rgb input is dissabled
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Dec 12, 2008 | LG 32LC5DC 32 in. LCD HDTV
Panasonic Pro idiom IMP 1200 hook up
This message is probably a year late but if your still looking for HD over standard coaxial cable to Panasonics IMP1200 media boards, the solution is ZeeVee. The new ZeeVee Pro250 looks very promising. Im about to use is in several local restaurants that currently have standard modulated signals. check them out at www.zeevee.com. You will need a Pro250 for each Cox HD cable box your running in the system.
Oct 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Computers & Internet Logo
14 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
