Question about Dishwashers
How do I find out if my dishwasher should have a countdown display or not?
Posted by tjiscrafty on
jws1013
  • 1,708 Answers
Read the owners manual or contact the manufacturer
Posted on Sep 21, 2019
Testimonial: "The manual covers many models and beside each feature there is an asterisk saying "depending on model" which is not very helpful. I had already emailed Bosch but have yet to hear back from them. I was hoping that someone out there had a list of features for my model. Thanks anyway."
FILLS, DOES NOT WASH, THEN DRIES
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
Tip
Thanks for the advice, it worked! For a few days I tried to cancel the blinking...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at [email protected] and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
What does the 2H mean? It seems to be the "standard" but the manual has no definition.
Great question!
2H means 2 hours -- 120 minutes ... the display only has 2 digits so it can not display 120 minutes. When the timer gets done near an hour an one half, it will start to display a countdown somewhere near 90 (minutes)
Yes, the cycles are long on the LG LDFxxxx dishwashers, just like all water and energy conserving dishwashers.
This really is a good dishwasher, recommend you keep the rinse aid dispenser filled up and ALWAYS use a brand name powder (like Electrosol or Cascade.) Also make sure when it was installed, it was properly leveled.
Hope this helps!
Mar 12, 2009 | LG LDF6920ST Stainless Steel 24 in....
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
