Sony KP-53S70 53" Rear Projection Television Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the same problem , but i had my for about 10 years.
When plugged in only the standby light is on. The power button will not turn the tv on manually or with a remote. I have the same problem. Only the standby light comes on, and blink only one time . There is no picture or sound. The TV controls and the remote control do nothing...
I would really like to fix it myself if possible. I can't afford to pay to get it repaired.
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Sep 15, 2009
Anonymous
Expert
Level 2:
Answers
80
Questions
Helped
20512
Points
193
You can look at the deflection board for a burnt up little blue capacitor, it will be 1picofarad at 2000 volts, if it's not that obvious, then you will need convergence chips or a flyback, you just can't troubleshoot that problem yourself.
My sinotec stl-32vn23 standby button doesn't want to work how to fix that?
If the standby button on your Sinotec STL-32VN23 TV isn't functioning, and the red light remains on without changing to blue, it could indicate a power-related issue or a problem with the standby button itself. Here's how to troubleshoot:Confirm the TV is receiving power from a working power source.If available, try using the TV's remote control to turn it on.If the issue persists, unplug the TV from the power source for a few minutes, then plug it back in and attempt to use the standby button again.If the problem still exists, it may be due to a technical fault in the TV's power circuit or with the standby button. In this case, it's advisable to contact a professional technician or the manufacturer's customer support for further diagnostics and potential repairs.
Panasonic plazma tv th-42pd50u. Red light automatically turns on when connected to power and stays on. No clicks, No blinks and No picture. Is this a faulty power supply board?
possible reasons, its in standby, hold in the proper ON button on the tv for up to 20 seconds gently. or try disconnect power(pull plug out) wait 10 seconds, plug back in and turn on using the actual button(holding for up to 20 seconds) NOT THE REMOTE if that does not work, make sure your INPUT is CORRECTLY selected eg you are viewing HDMI1 and NOT HDMI2 for example. there may be different procedures for flashing lights
2answers
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
1helpful
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Sony Trinitron
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
6helpful
5answers
My Sanyo TV DS20930 wont turn ON at all
try unplugging for the power source for 60 seconds hold in the power for 10 seconds then plug the power cord while you are hold int power button in then release the power button... now try it (turn it on)
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
