Question about Dishwashers
Hello, i have problem with the disposal of hoses since the carburettor to the machine, you may help me with some photo for fijarme and can install my carburettor? thanks
Ronald Rissel
    Master:
  • Dishwashers Master
  • 713 Answers
What are you talking about? What machine? What is a "fijarme"?
Posted on Oct 03, 2019
I bought dishwasher kenmore13443 water will not drain out of dishwasher
Hello. Don't know all the details and this may seem like a simple solution but if this was a new installation and you have it connected to a garbage disposal, check to make sure the knock out plug on the disposal is removed. It will be where the discharge hose connects to the disposal.
Apr 05, 2011 | Kenmore Dishwashers
Dishwasher not draining
Try to check if the hose is clogged..Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line..You should remove this line and clear it form any debris in the hose or the hose connection..Then reattach it before starting your washer again..Thank you..
Please post back how things turned on or further assistance..!!
Regards!!...
Aug 15, 2008 | Frigidaire 24 in. PLD2850 Built-in...
WE JUST BOUGHT A NEW DISHWASHER DU1345XTVB HOOKED EVERYTHING UP CORRECTLY AND RAN A QUICK CYCLE THRU IT AND WHEN IT WAS DONE THERE WAS STILL WATER IN THE BOTTOM. THIS WAS TO REPLACE THE OLD DISHWASHER SO...
Make sure the garbage disposal is working, if it is not then it will not allow
the dishwasher to drain. Also make sure there is not blockage in the intake port on
the disposal where the hose connects itself. If you installed a new disposal, there
is a knockout that must be struck out inside the connection port.
If you have an "air gap" installed (next to the faucet which looks like
a small cup upside down, it may be gunked up, remove and clean, or replace it)
If the hose came inside the dishwasher did you install it on the proper port on the
dishwasher pump, many have two and one is blocked off. (it is unlikely but depending
on the amount of water and the type of subflooring under the machine, it could have
pumped out unnoticed and drained through a wiring hole).
Hope this is helpful
Mar 26, 2011 | Whirlpool Dishwashers
The dishwasher does not drain, i just replace my garbage disposal and now the dishwasher does not drain, i did reconnect the dishwasher drain hose to the garbage disposal
Hello, Welcome to FixYa. I just came accross your post and immediately I thought, " drain plug in garb not punched out" this is very common when a new garb or dishwasher is installed..so much If I had a dollar for every one I saw or heard about I could be paid a couple of trip charges. If you haven't already done so, remove the drain hose from the garb and knock out the stop inside the spout. See your installation guide/owners manual ( for the garb/disposer ) if you still have it, that should show you "where" and "how". Let me know either way and I'll help further if necessary. Regards, Macmarkus :)
Feb 19, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Water will dot drain, washer overflows and leaks. new drain hose and new garbage disposal was installed.
Did you knock out the plug where the dishwasher drain hose connects to the disposal. If you did not that is the problem. Plumbers will even forget the plug every once in a while. In side the spot that the hose connects to the disposal there is a plug. Knock it out and make sure you do not leave it inside the disposal or it will jam it. Hope this helps. Rick
Mar 07, 2010 | Dishwashers
I installed a new bocsh dishwasher and garbage disposal. The water is not draining. I routed the drain hose on the floor rather than looping it up the back of the dishwasher, due the short lenght of drain...
If you did not remove the plug from the disposer drain where you made your drain connection will cause the dishwasher not to drain. This should have been mentioned in your installation instructions. Also, routing the drain hose other than what is specified in the instructions, will allow food waste to enter the dishwasher when you grind food in the disposer. Read your instructions and don't take shortcuts, you want to have your appliances work well for a long time, as you have made a considerable investment in some quality appliances.
Hope this helps!
Jul 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water remains in the bottom of the dishwasher after a wash cycle. We just put in a new disposal - works great! Hose is connected inthe correct place and seems to be free of gunk.
Hello sschneid,
New disposals have a knockout plug at the point of entry for the dishwasher, I assume you knew that and removed it. If not, then detach the dishwasher drain hose from the disposal and take off the hose adapter from the body of the disposal assembly.. with power disabled.. use a screwdriver to push the knockout plug out and remove it from the disposal grind compartment. Manufacturers leave that in there for peopel who need a disposal but don't have a dishwasher. Get back to me if that is not the solution and I wil help you resolve it..
Regards,
Rick
Nov 26, 2008 | Dishwashers
I am attempting to install a dishwasher drain line to a kitchenaid disposal under my sink. The disposal is a Kadette 250 1/2 hp. There is some kind of block or plug stoping the water from entering the...
Remove the hose from the disposal, take a hammer and long screw driver, put it in the hole where the hose attaches and knock the plug out. Turn power off to the disposer and pull the plug out of the disposer. Hope this helps.
Aug 09, 2008 | KitchenAid Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
