Project: Digital Media and Business - Computers & Internet
Posted by Anthony mendoza on
What are the processes and sub processes of a project
You can say processes are Initiate, Plan, Execute, Monitor and close.
You can refer to the PMBOK site for details on all stages and activities for a project.
Guide to the Project Management Body of Knowledge
Sep 03, 2014 | Microsoft Project 2010 Professional...
How to use adobe premiere pro 2
Adobe premiere pro is software for video producers that takes you from the start to completion of your video project. You will run into less conflict working with other video formats due to the "Native Editing Support" from "SD" to "HD" that is provided in this software. A convenience is that every workspace has a separate panel and when using multiple panels they can be docked where you want.
Please follow the below step.
Step 1: Open the premiere software and choose which project you will be working with, either a previous, recent or new project. No need to change the default settings at this time.
Step 2: Go to the "Capture Format" menu and choose the type of format you want to capture, for example from the web or a dvd. (http://www.ehow.com/internet/)
Step 3: In the dialog box at the bottom give your project a name and determine the folder you are going to use to save your project. Before you click OK, select the "Scratch Disks" tab to create your own folder structure, this will make it easy when it comes time for you to move the media and archive. Now choose the folders you want to store the captured media you identified in step 2 and when you are ready, click "OK."
Step 4: Work with your sequences in the "Workspace Layout." This area is divided into sections, the top left and middle contain the project panel, source monitor and effect controls. The top right of the workspace contain the audio mixer and program monitor. The left lower section contains the media browser, info panel, effect panel, sequence and history panel. The bottom right panel contains the tracks, time-line, clips and audio meter.
Step 5: Edit your sequences using the "Timline Panel." Each sequence you add will appear as a tab within the "Timeline Panel." You are not limited to the amount of sequences you create or number of timelines you open.
Step 6: Create your video and audio using the "Tracks" feature. Each clip you add to the sequence needs to have a track identified. This is where you are adding sound to your sequences within your "Timeline Panels."
Step 7: Trim your clips using the "Source Monitor." Here you can add or remove a sequence by double clicking on the clip in the "Project Panel." You can then play back the clips in the sequence you assembled to view your project.
Step 8: Access the "Project Panel" and "Media Browser" for links to the different aspects of your video project when you need to add, change or remove sequences. When you are ready, go to the "Effects Panel" and begin setting the desired effects to the sequences you created.
Step 9: Open your "Tools Panel," which provide shortcuts on the keyboard for several of the functions mentioned in earlier steps. This is the beginning steps in using adobe premiere pro, to continue to the end of your video/media creating follow the prompts.
Thanking you
davevipul197
Jun 02, 2011 | Adobe Computers & Internet
What type job of relationship manager
hi,
read the following.
ok
p { margin-bottom: 0.21cm; }h2 { margin-bottom: 0.21cm; }
The role of Business Relationship Management, or the Business Relationship Manager (BRM), is an emerging role in Information Technology (IT) organizations. The BRM is a liaison between IT and the business. The BRM has significant knowledge in subject matters pertaining to both IT and the business. The BRM is responsible to understand the business, assist in the prioritization of projects, ensure that projects align with the technology that best provides maximum return on investment, and direct IT strategy in support of the overall business strategy.
Business Relationship Management differs from Customer Relationship Management (CRM) in that BRM is an advocate for the business within IT without the external influences to sell product and keep a deal going. Also, the BRM is an employee of the same company as the business and IT organizations that are supported. The CRM is an employee of a third party company with different motivations for a different bottom line.
Responsibilities Responsible (Fulfills the task independently)
  • Pre-project business solution design
  • Has relationship with internal technology teams
  • Has relationship with external technology vendors
  • Identifies opportunities for operational efficiency
  • Service Level Agreement (SLA) negotiations
  • Directs projects towards desired technology strategies
Accountable (Fulfills the task by coordinating others efforts)
  • Overall solution delivery (project progress)
  • Project issue resolution
  • Develop long-range technology strategies
  • Provides initial project estimates for cost-benefit analysis
Consultant (Advises on the task)
  • Participates in technology aspects of business-sponsored RFx's
  • Evaluate project objectives
  • Project prioritization
  • New business initiative analysis
Informed (Is advised on the task)
  • Gains understanding of business strategies
  • Gathers information on competitor technology
  • Stays abreast of industry trends in the business and technology
  • Has relationship with research firms
  • "...involved with advanced or emerging technology groups within your IT organization"
Key Role Interactions Business Partners
The BRM works with the business at several organizational levels. The BRM will work with business area teams to understand project requirements, shape the initial project request, and provide a high-level estimate of the project effort and costs used in cost-benefit analysis. The BRM will regularly report back to business managers on the status of projects.
Application Architects
Early in the process, the BRM works with the architects to discuss potential solutions that match the business strategy with the technology strategy. The architects will also provide consulting on additional costs due to additional equipment or increased capacity requirements.
Project Managers
Early in the process, the BRM works with the PM's to discuss staffing needs, high-level timelines, and the associated cost. Throughout a project, the BRM will stay informed on the project status in order to provide business managers with regular status. Occasionally during the project, the BRM will be used in a facilitation role when an impasse between the technology team and the business team occurs.
Finance Managers
The BRM may also need to work and supply information through to either a dedicated IT Finance team or to Management Accountants within the Finance Function. This can cover involvement in the Organisation's annual planning process (The Budget), updates to forecasts, down to providing updates from IT Department & Project managers in helping analysis of IT spend to date.
Professional Skills The BRM needs to have subject matter expertise in both the business and technology. As such, it is not possible for the BRM position to be an entry-level position. Rather, this position requires the ability to understand the business sufficiently to communicate the importance of projects to the technology teams, as well as to understand the technology sufficiently to communicate the complexity in simple terms for the business.
"Additionally, attention to detail and good analytic skills are important because there are always a lot of interdependencies, and even a simple change could affect other applications or parts of the infrastructure."
nterpersonal Skills The BRM "straddle IT and business with these key skills:
  • Communication
  • Presentation
  • Critical Thinking
  • Collaboration"
Dec 29, 2010 | Panasonic Audio Players & Recorders
How do i convert .mov to something compatible with windows movie maker
You can add content to your Windows Movie Maker project either by capturing content directly in Windows Movie Maker or by importing existing digital media files. You can also import existing Windows Media-based content as well as other common file formats. You can import files with the following file name extensions into Windows Movie Maker to use in your project:
  • Video files: .asf, .avi, .m1v, .mp2, .mp2v, .mpe, .mpeg, .mpg, .mpv2, .wm, and .wmv
Dec 14, 2010 | Arboretum HyperEngine-AV 1.4
Will not respond to any physical instructions
Our ipod did the same thing last night I am on looking for a solution also please help school project due Sat and ipod is part of project
Apr 02, 2008 | Apple iPod nano 3rd Generation
Computers & Internet Logo
18 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
