Does my JRV9000 have an audio output so attach my ear buds
Posted by Keith Smith on
5 Related Answers
Anonymous
  • 265 Answers
SOURCE: Only the left ear bud has sound
Hey NoRightSound,
If your earbud headphones function normally with other devices, there are a number of reasons why this problem may be occurring, including faulty connections within the iPod itself or a potentially defective headphone jack. While both of these issues can typically be resolved fairly easily, I would first suggest contacting your local Apple-authorized service center for a complete diagnostic to pinpoint the exact cause of the problem.
Remember that if your iPod is still under the original manufacturer's warranty, you can always call Apple directly for technical support over the phone in addition to working with a technician in your area.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 30, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Posted on Dec 08, 2008
Anonymous
  • 17 Answers
SOURCE: only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Posted on Dec 26, 2008
Anonymous
SOURCE: Ear hook and ear bud replacements for Motorola H375
Here a site for replacements.
MOTOROLA H500 REPLACEMENT EAR HOOK $4.50http://www.worldwidecelldeals.com/store/
Posted on Apr 02, 2009
Anonymous
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
Can this be connected to the aux port of a car radio? how via USB or ear bud jsck?
Usually If the car has an existing audio jack port you should be able to use an audio cord that has a male audio jack on both ends and it should work. Just make sure your on the right output selection on the car stereo. (Such as aux, cd, tuner,)
Apr 01, 2015 | Mach Speed Trio Clip MP3 Player
No audio from center channel
You could check your voltages before and after you loose audio and see where the voltage changes. Working backwards from output to input. I use a signal tracer or a small wattage speaker such as a
ear bud. If you don't have access to a oscilloscope.
when using an ear bud I would start at the driver(low wattage)
the pa would blow it.
Sep 29, 2014 | Onkyo TXSR508 Receiver
Connect a 3.5mm ear bud jack
Fair warning, this response may be a dead end & be a waste of time. I can only refer you. In attempting to find a fix to your problem I did a little research. I am not sure that what I am telling you is even allowed on this site. On YouTube, type in ' Connect stereo to earbuds on BMW1200LT'. there is a vid showing stereo install. It may help. Sorry, I am a hardwire tech not a wireless guy.
Dec 25, 2013 | 2000-2009 BMW K1200LT Brake Pads
I have lost my speakers on the monitor. Using Microsoft XP, they were working but now they are not. Did some driver updates then lost the sound on the monitor. Checking the control panel indicates that...
Sounds like you've lost audio output from the sound card. Unplug the audio cable from the sound card and plug in a set of ear buds or headphones. If you don't get any sound your driver's not working. Try reinstalling the old driver.
Aug 08, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor speakers cannot function despite connecting the audio cable and checking the volume
nienqajm, Tell me if you hear anything if you connect a set of "ear buds" to the "mint" green color audio output connector "jack" on the pc!! Play a video clip with audio at YOUTUBE and you should hear something if audio not on mute. 12fixlouie
Oct 25, 2010 | NEC MultiSync LCD1525M (Black) 15" LCD...
I just purchased an LG W2253V monitor, have it hooked up and working just fine but I am not getting any sound. What might be my problem and how might I test this sound?
dbeffort, Try to prove that you have audio (stereo) signal coming out the "lite-green" audio output jack on the pc!!! Use a set of stereo headphones or "ear-buds" to prove audio is present. Let me know results of test. 12fixlouie
Sep 05, 2010 | LG Computers & Internet
I five klh speakers and bose amplifier, how can i connect it to my home hp pc
Perhaps you can specify which Bose amplifier you have. Presumably it drives the 5 speakers. Can you specify which computer you have? Do you have an add-on sound card? Does your computer have a 4 or more channel output? That is a different matter. Do you want the highest possible audio quality?
I'm going to assume the simplest configuration here.
1) There are two likely auxiliary input jacks for the Bose amp. One is a single 1/8" stereo jack. This jack would fit your ear bud headphones. Try this with it turned off. The other option are dual RCA jacks. These have a center opening around a cylinder about the size of a pencil. The center opening is about the size of that ear bud plug, but don't try and put it in there. The cylinder outside will have a metal ring.
2) Determine the output of your computer sound card. It is most likely a 1/8" stereo jack, so try your ear buds with it turned off. Many computers have a headphone jack and then a speaker jack. The speaker jack may be color coded green. You should be able to drive off of either of these but you will want to control the volume on your computer appropriately because the speaker output may drive too strongly for your Bose. Turn the volume up slowly.
So, then you need to go buy a cable. Here are two likely possibilities:
a) 1/8" stereo male to dual RCA male
for example: http://www.radioshack.com/product/index.jsp?productId=3449316
b) 1/8" stereo male to male
for example: http://www.radioshack.com/product/index.jsp?productId=2102949
Jul 21, 2009 | Audio Players & Recorders
Dec 07, 2008 | Radio Communications
Nov 24, 2008 | Motorola Mobility H500 Wireless Headset
32 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
