Question about Hardware & Accessories
My toyostove lazer 73 has too much soot
I just followed the directions from another fixya expert to try and correct and E2. The stove runs or a few minutes and then you get a strong kerosene smell and it ends up flashing E2. I've tried cleaning the white wire, red wire and gold nut. I unscrewed them all and tried to get the soot out but I still have an E2.
Posted by Debra Quigley on
Your Consultant
    Master:
  • 811 Answers
I am not a heating expert so take this with a grain of salt.
IMHO, a sooty burning oil burner (which kerosene is used in) is due to too much fuel or too little air. An oil burner consumes oxygen, therefore ventilation is required. A direct vent supplies makeup air and provides and exhaust path. Kerosene comes in a couple of different grades. K2 is generally used for heating.
SO, insure you have the correct type kerosene. Inspect your direct vent to insure it is drawing in air from the outside easily. Insure your control is not supplying too much kerosene.
The flame should not be red - that is a definite indication of too little air/too much fuel. If it is very blue, it may get blown out. Your manual should show you the perfect flame color.
If you are smelling kerosene, that would be a good indicator that something is wrong with your direct vent. Any leak between the exhaust section and the makeup air section will cause this. Reinstall the vent and insure the directions are followed. Moving the vent after installation is perfect for breaking the seals and creating the problem. Have you had any earthquakes lately?
Posted on Oct 04, 2019
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Posted on Dec 02, 2007
Anonymous
  • 8 Answers
SOURCE: Toyostove Laser 73 EE2
The firing sequence for a L73 is blink, blink, blink, on the green burner light, then it clicks up to the medium, amber or yellow light...that's when the pump kicks on. If you hear click, click, click, or thump, thump, thump, that means the pump is starving for fuel. The problem is from the carburaot/sump back to the fuel tank. You may have icing in your line or a line restriction, no fuel, plugged fuel filter or plugged sump screen. You can thaw your fuel line, until you have a free flow of fuel and then push the red restart button on top of the sump. Try to restart your Toyo.
If you follow the firing sequence and hear no click, click, click or thump , thump, thump and your Toyo goes off on EE2 then you can have a dirty flame sensor...the whilte wire running to a U shaped part that is the ground for the entire unit. You can take ythe ytwo phillips screws out, turn the part to the side and wiggle it out. Clean it qith a green scrubby or sandpaper and put it back in. Be sure it points stright down. Then take out the igniter which are the red wires. Put a long screw driver in there and rattle it around real good. You are trying to shake any carbon cxhains off the burner ring that can be "shorting" the flame sensor. You can also removee the 1/2 inch flare nut from the fuel nozzle...brass yellow colored metal part, and put a paper clip or wire down that about 3 inches. That will clear any blockage in front or inside it. Put everything back together, hit the red reset button on the sump and re-fire your Toyo. You might get it going in this manner. If not, you may need a tuneup because your Toyo is too sooted up to run correctly. Try these things and post back!
Posted on Nov 14, 2008
Anonymous
  • 126 Answers
SOURCE: Toyostove L-73
Rust,
#1 and #2 are not the same at all. Toyo Laser 73 heaters should only use #1 home heating fuel or Water Clear Kerosene. If you burn #2 in your Laser 73 it will soot up in less than a week. It is a disaster, do not do it!!!
The difference between the fuels is the amount of carbon in them. # 2 has a lot of carbon and therefore more BTU's of heat per pound than # 1. All that carbon will end up on the burner, blower and in the heat exchanger. It will be the dirtiest job you have ever done.
Posted on Jan 07, 2009
Dave Black
  • 17 Answers
SOURCE: my puppy ate the room temperature senser off of my
If the dog Just chewed the wires you can splice them back together
But if you need a new one I can Mail you one.
Call me
Total Toyo
(907) 488-9179
Good Luck
Posted on Dec 13, 2009
Brian Niten
  • 674 Answers
SOURCE: getting code EE 2 on a laser 73
EE 2 usually has to do with the fuel. Does the heater make a loud ticking or thumping sound? That's the sound the fuel pump makes when its not getting any fuel. Check your filter, check the strainer in the fuel sump. Depending on how cold it is any water in the fuel line could be frozen blocking the fuel flow. You might also check the flame rod for soot. It can be cleaned with some steel wool.([email protected])
Posted on Jan 25, 2010
Testimonial: "by the time that this information was available the problem was solve.dirty injector and flame sensor"
Do you know if they sell a replacement for the front louvered grill in the lazer 73? Mine is damaged and I removed it from the frame and need a new one.
Parts are available. Contact Valley Power Equipment, Customer Service Dept 1-877-360-3507
Monday - Friday 8am - 5pm ET, Saturday 8am - 1pm ET .
Hope this helped you.
Jul 01, 2011 | Rinnai Toyostove Direct Vent Heater:...
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
Jun 09, 2011 | Rinnai Toyostove Direct Vent Heater:...
Showing ee 8 wont start
Remove the front cover. Remove the 1 1/2 inch black hose that has a 90 degree bend into the silver box. With the stove OFF stick your finger in the hole and try to spin the fan. It may take a few times but keep trying it should break free. Once free the stove will work. If it spins freely and still gives the EE8 you wll need a new motor.
Tom
Sep 18, 2010 | Rinnai Toyostove Direct Vent Heater:...
Getting code EE 2 on a laser 73 toyostove that runs on kerosene
Jan 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
My puppy ate the room temperature senser off of my toyostove lazer 73,could you help me with where i can find one online or else where?thanks,carolyn
Call me
Total Toyo
(907) 488-9179
Good Luck
Dec 12, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 30
Yikes. On the front panel. That can't be good. Have it serviced. ;)
May 09, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73
A manual can be found online by googling Toyostove 73 and owners manual or manual. I use it often. It is at on the rural energy website.
Jan 13, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 56 EE 2 error
Tim,
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
[email protected]
Jan 06, 2008 | Rinnai Toyostove Direct Vent Heater:...
Hardware & Accessories Logo
129 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
