Question about Hobart Food Mixers
Having problems adjusting gears on Hobart D300 mixer. Replaced broken beater shaft & now only goes in high speed??? How to adjust???
Posted by Kitty Oden on
5 Related Answers
Anonymous
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Posted on Jan 20, 2009
Gearheadman
  • 4 Answers
SOURCE: Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Posted on Jun 10, 2009
Joe Hogan
  • 10865 Answers
SOURCE: How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Posted on Jul 10, 2009
Capt Rick
  • 81 Answers
SOURCE: Hobart D300 Mixer, Will not shift from 2nd to 1st
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Posted on Jul 25, 2009
Capt Rick
  • 81 Answers
SOURCE: Hobart D300 Mixer: Has no torque and no speed in any gear
You have a gear with broken teeth or one sliding out of place because the brass shims are eaten up. Hobarts have what is called a planetary, round head where the grease caps are, and there are no clutches for this planetary. These units are not made to change gears while unit is running (#1 problem of gear failure) (#2 is overloading the bowl) Hobarts need a really stiff GREASE, not oil. If you decide to take the planetary apart, get all the syrup out and replace with a stiff axel grease. It is a very difficult job replacing a gear & ALL the shims. The round head where the grease caps are can easily be removed to do this.
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
Hobart Mixer D300, When mixing mashed potatoes paddle will only turn in low gear. When product is mashed with milk added it sometimes will turn in 2nd gear, but never in top. When this happens, motor is...
Sounds like the keys in the shifting sleeve may be sheared. The transmission will have to be disassembled and checked for broken parts. Check www.hobartservice.com for your local Hobart office.
Jul 07, 2011 | Hobart D300 Stand Mixer
Hobart d300 spins but slips under load
sounds like you have a sheared key in one of the gears. which speed is it slipping in or is it all 3speeds
Dec 04, 2009 | Hobart D300 Stand Mixer
Hello i would like to know what kind of oil to use on a Hobart mixer d300 its a 3 speed mixer the problem im having is 3rd speed runs like 1st speed could it be the clutch that is bad thank you
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
Nov 16, 2009 | Food Mixers
Jul 10, 2009 | Hobart D300 Stand Mixer
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Jan 11, 2008 | Hobart A200 Stand Mixer
Slips in all gears
you have no speed 1,2,3 right?first thing to do is drop the planetary (this is the bottom with the beater shaft)undo the bolt and it will drop down.you will see 1 gear,that gear should not spin without the shaft spinning too.if it does you have a sheared key on the gear.if you have access to the transmission check the worm gear attached to the motor it has a roll pin through it make sure its not sheared.then look at the top left gear assembly and check for sheared (broken)keys.clean up all the parts,if you dont you could miss something.let me know.
Aug 22, 2007 | Hobart D300-6036 Mixer
Food Mixers Logo
153 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
