Question about Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C
We have a cusinart dcc3000 and the coffee gauge just stopped working. It is on full all the time
Posted by Bob Finocchio on
4 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Posted on Mar 14, 2009
NORMAN ZINK
  • 85 Answers
SOURCE: No Brew...?
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
espressonist
espressonist
  • 1711 Answers
SOURCE: temperature gauge has stopped working
the pipe that is connected with boiler is blocked from scale. You can try to removed it and descale the pipe.
Posted on Feb 17, 2010
I need a manual for a cuisinart coffee maker - older model
If you go to Manualsonline.com and start clicking on Kitchen Appliances>Coffee Maker>Cusinart Kitchen Appliances>Cusinart Coffee Maker. Then you can choose your type and download the manual free. Or an easier way is once you are in Manualsonline.com Click on Brand > see all>Cusinart>kitchen appliances> Coffee maker>your type. Download the maanual free. I hope this will make your search easier. Kolbrun
Nov 02, 2013 | Cuisinart Coffee Makers & Espresso...
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
Mar 09, 2011 | Microwave Ovens
I have a cusinart DCC-1200 Series, So how do I keep my coffee hot all day long ?
Brewed coffee has a palatable life-span of maybe an hour before it loses flavor. I don't recommend keeping it any longer. The thermos should keep your coffee hot enough to drink for some time. If you really want to drink from that same pot all day long, I'd probably just reheat a cup at a time in a microwave.
Sep 30, 2010 | Cuisinart DCC-1200 Coffee Maker
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Its not making the coffee its just makes a little then stops
You both may have deeper issues, but it is definitely not too new to be decalcified. It is very much worth a shot. I have a Cusinart coffeemaker and a Cuisinart espresso maker, and both of them needed to be decalcified in the first month (of course, I live in an area with hard water).
-Tha Mp3 Doctor
Jan 25, 2009 | Cuisinart DCC-1200 Coffee Maker
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C Logo
185 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
KBeaN1
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
