Question about Denon Televison & Video
Have a denon adv-m71 that will not turn on.
Already try the unplugging procedure and still nothing. Any ideas?
Posted by Alfredo Salvattero on
3 Related Answers
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: I am at a hotel
Yes it can be Denon unit is a flexible there nothing to wory about,yes you can access the receiver menu also.txt me whatever happens.
Posted on Jun 17, 2008
Anonymous
SOURCE: Denon ADV M71 CDVS
Denon ADV-M71
Posted on Dec 14, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Denon adv-500sd will not play discs!!
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jan 11, 2009
My icom m71 has a mic prob people can't hear me ,
PLAESE GO THE SERVICE CENTER AND CHANGE THE MIC ACCESSORIES.....
Mar 09, 2013 | Cell Phones
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
How do you clean the optical lens
You can buy sens cleaner disc from most of the electronic spare part selling shops. buy one and insert it into the player. It will clean the optical lens automatically. The disc won't cost more, and can be used repeatedely.
May 22, 2012 | Denon ADV-M71 DVD Player / Receiver
Denon adv-700 - Mech error
try to disconnect your system from power and connect it again.
Sep 06, 2008 | Audio Players & Recorders
Denon ADV 700
If counter is running the disk is being read. Check your settings and/or wiring.
Sep 17, 2017 | Audio Players & Recorders
Protector flashing red when off.
If the speaker wires are shorted, it may be in protection mode. Try turning it on with no speakers attached.
If you've already done that and still have the same problem, it's broken and you should return it.
Dec 20, 2007 | Denon AVR688
Televison & Video Logo
41 people viewed this question
Top Denon Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
