The Brother MFC -210 does not see the cyan inkcartridge.
Al four cartridges were replaced with new inkcartridges . But the Brother MFC-210 does no see the cyan inkcartridge and the other three as empty inkcartridges . What can I do to solve this problem .
HELLO THERE can u tell me if these are the right cartridges for this unit cause there is a big diference if you use the wrong cartridge if it is youare going to haveto go to the maintanence section and reset the cartridge there and than go from there ok best regards michael
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
could you please confirm that all the stick stuff is off the chip on the cartridge, and check the pins on the printer side were the cartridge fits is clean.
Since your printer is new, is should be covered under guarantee. Please take it back to your dealer, he should swop it out. Alternatively you can arrange a replacement from Lexmark direct through their website.
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
I found a small plastic "clip" of the type that covers the print-head of a cartridge in the mechanism where the printhead/inkcartridge is mounted. I have no idea where it came from nor how long it had been in there but the printer works OK after I removed it.
