Question about Microsoft Windows XP Professional for PC
Windows XP MYST 10th Anniversary DVD Edition CD DVD ROM reader can not read disk format what format was used?
  • 4 more comments
  • Anonymous Sep 15, 2009
    Sure
    I have Windows XP Media Center Edition
    When I put a CD in the CD drive there is no result. Under "Properties" I read that it is a blank tape. When I took the CD back to "Best Buy" where I purchased it, their PC clearly shows that there are files on the CD.
    When I used FixYa the message is "can not read media format".
    I would like to find the proper software that will read the "format" and use the CD.
    Is this restatement clear enough?
  • Anonymous Sep 16, 2009
    My thanks to LuckyLuke78 for trying but alas no resolution. The software site I was sent to will only work for DVD's. It will not recognize my CD.
    Here's what I have
    under "My Computer" drive is titled
    DVD-RW Drive
    Properties hardware shows
    TSST corp CD/DVDW TS-H552L
    TYPE- DVD/CD=ROM drive
    Version- 5.1.2535.0
    Driver files
    C:\Win\Sys32\DRIVERS\cdrom.sys
    \DRIVERS\imapi.sys
    \Drivers\PxHelp20.sys
    \DRIVERS\redbook.sys
    \storprop.sys
    one apology I must make, product IS listed as a "DVD" on the box it came in.
    Microsoft Fix it, when asked to read and check this drive says
    "Media in CD/DVD drive is not readable" and shows the drives hardware name
    I bought the DVD at BEST BUY and their computer shows that files do exist on the disk.
    Do I need a different CD/DVD driver? or is there a software to add to the current driver?
    Thank you for bearing with me and my headache.
  • Anonymous Sep 17, 2009
    Here are some results
    CD with pictures works fine
    Audio CD works fine
    Older game DVD works fine
    Movie DVD same problem
    driver does not recognize DVD and I tried all the Autoplay options
    Yes sir
    Again thank you for trying to help.
    Guess I'll go to Best Buy when I get a chance and see if they will tell me which media player their system uses as it seems to work.
  • Anonymous May 11, 2010
    No, I am still in search of resolution. Your Fixya software is starting to look like a left handed advertisement to help you folks generate more revenue.
David Parker
  • 333 Answers
You will normally need the right software/program to view some formats, and I would recommend VLC media player as it does most and you can download it here for free:
http://www.vlcmediaplayer.info/london3/
Please leave fair comment if I have helped you.
Thanks
Posted on Sep 16, 2009
  • 2 more comments
  • David Parker
    David Parker Sep 16, 2009
    Sorry,have I read the question wrong?
    Do you need your player to see'Windows XP\r\nMYST 10th Anniversary DVD Edition',because this is on a DVD I presume?
    If you are trying to play a dvd, you need a dvd player or it will show 0 bytes if you only have a cd-rom.
    Maybe tell me exactly what you are trying to read and on what type of disc and what model cd-rom or dvd player you have and we can go from there.
    thanks
  • David Parker
    If you downloaded vlc media player that I sent you the link for and installed it(when inserting disc choose VLC media player not windows media),then it should read your dvd.If not and no other dvd's play then it is not normally a sofware issue, and probably the dvd player itself.
  • David Parker
    David Parker Sep 17, 2009
    It sounds like the dvd might be OK then.Did you try the VLC player?Movies normally require dvd software like VLC, whilst games do not.
    Please get back to me
    thanks
  • David Parker
    Could you possibly leave some comment or better rating?
    It takes time to research some questions and post solutions, and it would just be nice to know whether I have helped.
    Thank you
Unable to complete windows installation
try formatting the drive or use a different drive
Apr 10, 2014 | Microsoft Windows XP Home Edition
Dvd rom driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Oct 28, 2012 | Microsoft Windows XP Professional for PC
My computer formatted i have genuine product key how to get win xp home edition and install in my computer
Put the genuine Microsoft CD-ROM disk into your CD-ROM drive.
Restart your computer.
As soon as it starts, look for a message like "press Fxx to temporary change boot-order".
Press that key.
Select to boot from you CD-ROM drive.
This will start to install Windows, by reading from the CD-ROM drive.
Apr 23, 2011 | Microsoft Windows XP Home Edition
Media center does not play cds or dvds please help
You have to check your CD/DVD Rom to make sure the device is not faulty.
Open your Windows Explorer, insert any CD/DVD to see whether your CD/DVD is able to read the the disk.
If it cannot read the disk, most probably the CD/DVD rom is faulty and you have to replace it.
Aug 17, 2010 | Microsoft Windows XP Media Center Edition...
Can i boot win vista cd? can i use vista cd to reformat my computer?
Yes you can format computer with vista disk and instal new windows.
Inser that vista disk into cd/dvd rom then when you power up the computer press F1 or F2 del or ALT+F2 key to enter in bios.
Then go to boot menu and set first boot device as cd /dvd rom then save settings and exit from bios.
Then it boot with windows disk.Then follow the procedure and choose installing new windows xp then select 1 partition and format it then it install windows vista on it.It will take 30 to 45 minutes to complete the installation.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 13, 2010 | Microsoft Windows Vista Ultimate Edition
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
UNABLE TO BOOT FROM WINDOWS XP
First Make sure your cd/dvd rom detected in bios.
For that First open cpu cabinet refix power cable and ide cable to harddisk.
Then check your bootable recovery disk and cd/dvd rom working fine.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with disk .
If still not boot then there may be some issue with cd/dvd rom or bootable disk.
Let me know if you need more assistance.
Thanks.
Oct 13, 2009 | Computers & Internet
Cant burn a CD/DVD on the Samsung DVD-Rom SD-616Q
This unit can read most formats, but it doesn't support write operations.
Mar 26, 2009 | Microsoft Windows XP Home Edition
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
271 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
