Question about Precor Exercise & Fitness
Error 30 el?pticas precor - Precor Exercise & Fitness
Posted by Luis Leon Barrera on
What is error code 30 mean on the precor 9.32i treadmill?
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Aug 25, 2014 | Precor Premium Series 9.31 Treadmill
How do you fix an error code 30 on a precor 954i?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jun 30, 2014 | Precor Exercise & Fitness
Precor efx546i error 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jun 25, 2014 | Precor EFX 546i Elliptical Version 4
What is error 30 on the precor 9.33i treadmill?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Feb 16, 2013 | Precor 933 Premium Series Treadmill
Error 30 on precor 546 efx
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Feb 08, 2013 | Precor EFX 546i Elliptical Version 4
Precore efx 546 error 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 31, 2013 | Precor EFX 546i Elliptical Version 4
Error 30 for elleptical precor efx5.23
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
May 31, 2012 | Precor EFX 5.23 Elliptical Fitness...
Error 30 problem for 556 precor elliptical
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Mar 03, 2012 | Precor EFX 546i Elliptical Version 4
How to fix Precor EFX 5.17 error code 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Nov 01, 2011 | Precor EFX 546i Elliptical Version 4
What does error code 30 mean on the Precor efx 576i?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jul 16, 2011 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
121 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
