Question about PfaFF Sewing Machines
How do you take out the hook on the Pfaff 2046 sewing machine? Thread is tangled and its stuck.
Posted by Elizabeth Aagard on
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
Anonymous
SOURCE: bobbin tangle
can not thread bobbin...bobbin on top
Posted on Apr 27, 2008
Anonymous
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
Sewtech1
Absolute Sewing
  • 69 Answers
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Posted on Jan 20, 2010
Anonymous
SOURCE: thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Posted on Jan 25, 2010
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
Pfaff 3.5 was working fine,suddenly thread is bunching/getting caught under plate.Thread goes around the bobbin ok,when gets near to needle gets stuck on hook on right side.Any idea how to fix please?
Just guessing. You might try :
Installing a brand new needle
tightening the top tension a bit
If it continues to be a problem, most likely the machine is out of time and requires adjustment. Search for sewing machine timing or take it for service.
Apr 24, 2017 | PfaFF Sewing Machines
I have pfaff 2046 and the bobbin case will not face upwards. it is tilted to right side a little
Have you got your bobbin case and the area around it cleaned? This sort of thing often happens because there is a bit of lint stuck in the bobbin mechanism. Also, oil it! All sewing machines need a bit of a lube, even the new computer driven ones.
Nov 20, 2014 | PfaFF Sewing Machines
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
I have a Pfaff Quilt Expressions 2046. The bobbin casing is turning and not staying still. I can rotate and get it to snap up at the top but it will not stay in that position. I have cleaned and oiled,...
I suggest that the sewing machine be checked to see if there
is something wrong with the hook & hook race or if the bobbin
casing needs to be replaced
Oct 08, 2012 | Sewing Machines
Jan 18, 2010 | Sewing Machines
Sewing design thread breackage
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
87 people viewed this question
Top PfaFF Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
