Question about Pro Office Equipment & Supplies
Office edge pro 4000 won't print. it thinks it is but no print come out
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: Fargo Pro-L Not Printing Edge-To-Edge
These direct-to-card printers do not print right to the edge because of the way the print head comes down on the card. There will always be a white boarder on the card especially if your graphics are dense. The only solution to this issue is to re-design your artwork so that the image fades at the edges of the card so the white boarder is not obvious, or purchase a re-transfer printer which will give you true over the edge printing.
Posted on Jul 20, 2009
Where is the printer ip address?
You should be able to print the settings from the printer. Press the menu button and go to the reports and print the settings. You can also load the drivers and they will search your network for any available epson printers. I have included a link to the downloads page for documentation and drivers.
Epson Stylus Pro 4000 Print Engine
Sep 08, 2015 | Epson Stylus Pro 4000-PS InkJet Printer
Epson service required
Go To Below official Epson Printer Page For Your problem, Epson Stylus Pro 4000 Print Engine Still having Problem Then follow Us For Epson Printer Support
Feb 22, 2014 | Epson STYLUS R230 InkJet Photo Printer
Black only text won't print
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 04, 2013 | Epson Stylus Pro 4000 InkJet Printer
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
Epson stylus pro 4000 i have a clogged nozzle cant move it other 7 are fine
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 03, 2011 | Epson Stylus Pro 4000 InkJet Printer
How do I print on both sides of the sheet?
If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
Office 2007
  • Open your Office Document
  • Click on the Office button in the top left corner of the screen officebutton.gif
  • Click Print and select one of the printers that will perform duplex printing
  • Click on the Properties button under the Layout tab
  • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
  • Choose Long Edge If your page is set up as Landscape
  • Choose Short Edge . Click on OK again to send your work to the printer
Other Applications
  • Go to File and Print
  • Select one of the printers that will perform duplex printing
  • Choose Long Edge if your page is set up as Landscape
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Will not print to size
There are "default" paper options that can be set from the epson software you may need to alter these to suit your regular paper size.
Also if you are printing from MS office you can select sizes from there too.
It is better if both are set to the same.
Aug 11, 2009 | Epson Stylus Pro 4000 InkJet Printer
Epson Stylus Pro 4000 is printing green instead of black
Hi mariann346i am having the same problem with my EPSON RX 595 printer.
i can not print in black and white, it always prints in green.
i also notice something els, even after refilling my six cartridges
and only trying to print in black and white, my yellow ink is running out just as fast as my black so i guess they are somehow mixing together. you should check to make sure your yellow isn`t doing the same.
Jul 14, 2009 | Epson Stylus Pro 4000 InkJet Printer
Dec 14, 2007 | Fargo Pro L ID Thermal Printer
Top Pro Office Equipment & Supplies Experts
ray gallant
 Russ Hill
Russ Hill
Terry
Terry
Are you a Pro Office Equipment and Supply Expert? Answer questions, earn points and help others
