Question about KitchenAid KEMC377K Convection / Microwave Oven
Microwave humming Our kitchenaid microwave began humming when I turn it on. I am afraid to use it. What could be the problem and what should I do to fix it? Is it worth fixing? Thank you!
Posted by larochell730 on
  • William Miller
    William Miller May 11, 2010
    What is the full model number from the tag in or on the unit?... Is it actually heating when you don't want it to? ... Has it ever shown error code F2 or other code in the display? ... NOTE: FixYa's Web site is currently not
    notifying us when replies to our Clarification Requests are posted, so
    please reply back directly to me for free help and tips. ...
    William E. Miller - [email protected] -http://www.microwavedisplay.com http://www.fixya.com/PostAnswer.aspx?thi... ...
    * * * Please include the entire text above and your answers / more details, when you e-mail. * * *
romy sibug
  • 269 Answers
Hi! humming are cause of many things, either you have a defective magnetron, leaky capacitor, or the hv transformer. but most likely the magnetron is the culprit.
Posted on Sep 15, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 15, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Loud humming sound and microwave does heat
either your H.V. diode or H.V. Capacitor are open and not building the 2,000 vac for the magnetron tubes high voltage section
Oct 03, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
KitchenAid KEMC377K Convection / Microwave Oven Logo
348 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
