SOURCE: looking for a replacement pitcher
Just this morning I called Hamilton Beach directly. You can buy one from them.
The number is 1-800-851-8900
The pitcher, by itself, is $5.99
Shipping is $5.50
Tax is determined by the state you live in!
Give them the SKU #40911
Hope that helps!
SOURCE: Where can I get Mr Coffee Tea Maker manual online
Give this a try.
http://www.mrcoffee.com/manuals/MrCoffee/tm30p.pdf
SOURCE: How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Testimonial: "Great! Thanks for the advice. That's what I needed to know. Can't believe you answered so quickly. Wow!!"
SOURCE: MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
SOURCE: BVMC-PSTX91 MR COFFEE....ONLY USED ABOUT 15 TIMES
Mr.Coffee guarantees their machines for one year from the date of purchase. If you still have a receipt I would contact them. If not there could be a problem with the board on the inside of the machine. Which, unfortunately, is not available yet to purchase so your machine can be fixed.
