Question about Hobart Food Mixers
How much gear oil should i put in a Hobart 4246 HD grinder
Posted by Pat Khawly on
3 Related Answers
Tam Nguyen
  • 3 Answers
SOURCE: hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
You can buy food grade grease from kitchenaid or on amazon. I did use the grease from my work. Any grease would do the job just make sure you read the specifications to find the grease that can stand high heat so it doesn't melt while the machine is running.
Posted on Dec 14, 2011
J. Hobart Tech
  • 20 Answers
SOURCE: hobart D300T mixer oil change.
You can put in a all purpose grease. I use MOBIL 1 Synthetic Grease (RED IN COLOR) and it works fine -- you will need 3 tubs of 16oz's each tub. The cost is 30.00 or so. Make sure to get all of the old grease out and pack around each of the trans and worm shafts with the grease, then pack around the MOTOR GEAR and then put all back together. While running it make sure you can see the grease and hear the noise of the mixer through the 2 caps that are FILL caps on the head of the mixer. ALSO, you will find that you will lose 1st gear IF you have tigtened down too much on the LOCK nut, SOOOO loosen in small increments until all 3 gears are perfect and strong. ALSO, the key to noise adjustment is to Tighten (WHILE MIXER IS RUNNING) slowly the large nut that controls pressure on the worm transmission. The general rule with tigtening this nut is to tighten it till it will not tighten and then back off the nut -- IF the unit when starting does not run or it seems bound up when you first turn it back on, THEN you have tightened it TOO MUCH, SOOO back it off again (loosen it) until it starts smoothly and when you turn the mixer OFF it should come to a slow stop and not abruptly stop the mixer. Hope this helps some of you out there trying to do your own adjustments --
Posted on Apr 13, 2014
Vernon Taylor
  • 6546 Answers
SOURCE: I have a Hobart model 4332 meat grinder what type of oil is supposed to be in lower gear box I know it needs to be Food grade any suggestions would be great Thanks.
Contact a specialist oil supplier and ask them for their recommendation.
Posted on Dec 15, 2017
My Hobart grinder is old vintage it has 3 or 4 oil ports do I still use Mobil DTE HM OIL? How much in each port?
Steve I dont know that that is necessary. I have 2 a big heavy monster and a little #12 and I check for full and keep going. I only use mine in winter for sausage and its 50# in 120 sec. not much wear and tear on the lube. I know Hobart has a good web and mobile service here. Mine are Old and I'm guessing yours are too.
http://www.hobartcorp.com/
Jan 10, 2016 | Hobart Food Mixers
I have a hobart 4642 mixer grinder that s leaking oil Need help with diagnosing
can you confirm the model number and where the oil is leaking from?
Hobart make a 4246 and a 4632, but I am not familiar with a 4642
Feb 11, 2014 | Food Mixers
How many liters of oil?
How many liters of oil for what?
Oct 17, 2013 | Hobart Food Mixers
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
What kind of oil should I use in my Hobart 800 floor mixer? [email protected]
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Mar 06, 2011 | Hobart Food Mixers
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Hobart A200
Yes A-200 are number 12 I would find a hobart grinder they will have a big H in the casting on the neck get one with a stainless pan and stomper to push product down the throat. If you wait on Ebay and put it on your watch list they do come along. look for no rust. Make sure it has the big H in the casting. the other after market ones seem to not last long like the metal wears on the worm and hub to fast. also you always know where to get a piece if you need it if its a Hobart. not so with the forign jobs.
Dec 29, 2008 | Hobart A200 Stand Mixer
Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
May 05, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
163 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
