Question about Belkin Computers & Internet
Belkin hi-speed usb 2.0 7-port hub f5u237 not working with windows 10
Posted by Susie Ince on
The Spaminator
    Brigadier General:
  • Belkin Master
  • 487 Answers
Susie take a look at window 8 similar problem look at rimshots answer
http://www.fixya.com/support/t6138715-belkin_f4u017_7_port_usb
Posted on Sep 20, 2019
2 Related Answers
jfletch135
  • 15 Answers
SOURCE: I just purchased the belkin
go to the belkin website and download the necassary drivers and software for your system
Posted on Apr 13, 2011
jcs3082
SOURCE: I have an Belkin (F5U237) 7-Port USB Hub that is
if Win7-64 is installing this hub as a "Broadcom Bluetooth Device" or some such nonsense, heres a fix that has FINALLY worked for me...
START > CONTROL PANEL > HARDWARE AND SOUND > Device Manager.
Plug in your hub, and when it pops up under bluetooth radios with an error, right click, then select properties.
Under properties, select the DRIVER tab, then select UPDATE DRIVER.
It should prompt you to choose between "Search Automatically..." or "Browse my computer..."
Choose "Browse my computer for driver software."
It should bring up a location box to search, but there should be an option below the box that says "Let me pick from a list of device drivers on my computer."
Select this option.
This will bring up a list of drivers available.
UNCHECK the "Show compatible hardware" box!!!!!!!
Then browse until you see (Generic USB Hub). Select the first driver on this list and it will work.
The windows generic driver file that works with my hub is in:
C:\Windows\system32\drivers\usbhub.sys
If the above solution doesn't work, you can try to navigate to this specific driver file during a manual installation. Good luck.
Posted on Aug 01, 2011
Does the F5U237 work with windows 10
Yes it will but you may need to make sure that you have the latest driver installed for it to work its best. If Windows 10 doesn't automatically install the latest driver, it can be obtained from www.belkin.com
Mar 22, 2016 | Belkin (F5U237) 7-Port USB Hub
Does the F5U237 work with windows 8.1
It looks like Belkin stop support on certain models of Belkin, even thou you don't state the version model. But if you have a chance, visit this microsoft website which explain that it's not compatible with Windows 8.1
http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20N%20USB%20Wireless%20Network%20Adapter&vendor=Belkin&ModelOrVersion=F5D8053&Type=Hardware&tempOsid=Windows+8.1
Oct 19, 2014 | Belkin (F5U237) 7-Port USB Hub
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
F4U017 Belkin 7 port USB hub. No matter what i do, i cannot get this hub to work, i'm running windows 7 ultimate Home, i've updated and updated, it has got something to do with the...
Rimshot64, you did help someone out here. Two years later, even. And you succeeded where Microsoft "Help," per its tradition, failed. Thank you -- I got my scanner and printer, etc., back, and wasted only half a day uninstalling Microsoft updates (their suggestion).
Aug 02, 2011 | Belkin (F5U237) 7-Port USB Hub
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
My OS is Windows Vista Home Premium edition. Will Belkinns 2.0 x 7 port hub F5U237v1 will work with it?
Yes it will definitely work it no matter what operating system your computer is using it will be working fine.
Nov 25, 2010 | Belkin (F5U237) 7-Port USB Hub
I have an Belkin (F5U237) 7-Port USB Hub that is not compatable with windows vista. Is there a fix for this?
Select this option.
Mar 15, 2010 | Belkin (F5U237) 7-Port USB Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
Computers & Internet Logo
19 people viewed this question
Top Belkin Computers & Internet Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Mike
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
