Question about Casio Music
How do I get my Casio CTK 533 to continous play?
Posted by Elva Helm on
5 Related Answers
Anonymous
  • 192 Answers
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
Posted on Feb 10, 2010
Fred Yearian
  • 5603 Answers
SOURCE: My Casio CTK-496 Keyboard has three keys (2nd
First make sure a keyboard "split" option is not set.
Probably you are going to have to clean the key contacts. They are likely conductive rubber "pills" that are pressed onto a circuit board that has interleaved fingers. Clean both the black pills and the circuit board using ONLY 99% isoprophyl alcohol and Q-Tips.
Posted on Feb 18, 2010
Testimonial: "Worked perfectly. Keyboard plays like new. Thanks!"
Fred Yearian
  • 5603 Answers
SOURCE: no display light on my casio ctk 496 every thing else works
Sorry, but many of the low end keyboards do NOT have backlights. This is especially true of those that have the capability of running off batteries like the CTK-496.
The display in this is a reflectance type that needs ambient lighting to view.
Posted on Mar 13, 2010
Anonymous
  • 62 Answers
SOURCE: Casio CTK 800 spare key
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD or call casio and explain to them what happened and see if they can help :) Steven.
Posted on Apr 16, 2010
Anonymous
SOURCE: Casio CTK-651 keyboard wont switch on
i want to repair the casio organ ctk 651 or ctk 731
Posted on Oct 19, 2010
Sneed operators manual for model ctk 519 Casio piano keyboard
Many Casio electronic instrument manuals are available here: http://support.casio.com/en/manual/manuallist.php?cid=008 . However, I found the CTK-519 manual at Manuals Lib: https://www.manualslib.com/manual/358021/Casio-Ctk-501.html .
I hope this helps.
Apr 19, 2018 | Casio Music
Casio CTK-533 MANUAL
Google would be the way to search for one .
Feb 16, 2017 | Casio Music
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have casio CTK 5000. i want to download additional tones and rhythms on it . kindly suggest the site as well as the file formats it will recognize for this model. also kindly describe the total procedure...
It is possible to load new rhythms and tones in the CTK-5000. But you need the stuff. That is what it really lacks. Casio needs the Rhythms and tones in its own formats.
May 15, 2011 | Casio CTK5000 (61Key Portable Keyboard)
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 | Casio Music
My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Jun 18, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Dec 30, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
140 people viewed this question
Top Casio Music Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Tim Brauer
Tim Brauer
Are you a Casio Music Expert? Answer questions, earn points and help others
