I have a DP-101P+ wireless print server on my HP LaserJet. I recently purchased a new laptop and am trying to connect to the print server but so far no success. Any thoughts.
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
I connected my HP5MP to the DP-300U LPT1 port. I configured my port on the DLink Configuration tab, giving it a name "hp5" ...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax Click the + to add a new printer Select the IP option Choose the Protocol: Line Printer Daemon - LPD Type in the Address: 192.168.0.10 Type in the Queue: hp5 Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...' and find the driver for your HP LaserJet 5MP. Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Hi
How to check the print server is in the wireless network or not!!
Check under the Router Setup page Router's ip address...
Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range..
If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN...
Try the following steps.
1. Go to run and type "cmd" press enter
2. type ipconfig.
3. Check the range of ip address...if its 192.168.0.XX
4. Try pinging that ip address..
5. If able to ping the router and print server.. Then the wireless network is fine...
Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
