Question about Casio Office Equipment & Supplies
Can i set the time on a Casio HR-170RC printing calculator WITHOUT the seconds displaying?
Posted by Marianne Amaya on
5 Related Answers
Anonymous
SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
Posted on Feb 11, 2008
Anonymous
SOURCE: Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
Posted on Nov 14, 2008
Anonymous
SOURCE: how do I change the ribbon on my casio hr-8tm calculator?
Place the roll on the wire thing at the back (I don't think it matters which way round); push the paper through the slot at the bottom of the back and then (having taken the clear plastic cover off) push it along the bottom inside at the back as far as you can then start to press the feed button; keep feeding it with your finger and pushing the feed button asnd it should pick up eventually.
Posted on Feb 23, 2009
Anonymous
  • 81 Answers
SOURCE: how to set date and time on a casio qa-300 calculator
Are you sure that there is such calculator, look here casio calculators manuals:
http://www.theusermanualsite.com/ex/thread/view/idThread/1647547
Rate me if it helped
Posted on Jul 08, 2009
Anonymous
SOURCE: CHANGING THE VAT SETTING ON HR-8TEC CALCULATOR
1-press and hold "SET/%" key 2- "set" will appear on screen 3-press "tax+" key 4-type tax amount ie 17.5 5-press "set" key to complete done.
Posted on Sep 04, 2009
Testimonial: "Many thanks. A simple task but without the instructions, difficult. I have saved the instructions so when vat goes back to 17.5% I can change it back."
We hit a button on Casio HR-170RC and now it keeps rounding up. How do we stop this?
It is the slide switch for decimal places. You needs to be set to 2 places.
Slide Switch ' Printing Calculators ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > Printing Calculators
Q1: What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for? (HR-8 series); A1: The HR-8 series have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4]. The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F ... Missing: 170rc
HR-170RC ' Calculators ' Manuals ' CASIO
support.casio.com > Support > Manuals > Calculators ·This page might be unreadable or wrongly displayed depending on your browser, OS version, and settings. In this case, please try with different browser (Chrome, Firefox, etc.) ·We recommend you to download the large PDF files from this site and view them off-line. [ To download a file ] 1.Align your mouse pointer with the ... Missing: rounding
[PDF]HR-170RC HR-200RC - Support - Casio
support.casio.com/en/manual/004/HR-170RC_200RC_WA_EN.pdf - Translate this page
Mar 15, 2017 - Back-up Battery. Your calculator comes with a single built-in CR2032 lithium battery that provides power to retain values stored in memory when you leave the calculator without power (AC ... Weight: HR-170RC: 570 g (20.1 oz) including batteries ..... performed with values as input, and the result is rounded.
Slide Switch ' General Calculator ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > General Calculator Q1: What is the use of the Slide Switch? A1: F: Floating Decimal CUT: Values are cut off to the number of decimal places specified by the current Decimal Place Selector setting. UP: Values are rounded up to the number of decimal places specified by the current Decimal Place Selector setting 5/4: Values are rounded off (0,1 ...Missing: 170rc
Mar 01, 2018 | Casio Office Equipment & Supplies
Change tax rate
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Jan 04, 2011 | Casio MS-80TV Scientific Calculator
I have a tax + and a tax - button on a casio hr-8ter, how do i change the vat to 20%?
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Jan 04, 2011 | Casio Office Equipment & Supplies
Change Tax+ rate from current 8.25% to new, required 9.25%
http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE#0
How do I program tax rate into my calculator?
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Apr 01, 2009 | Casio MS-80TV Scientific Calculator
Casio calculator HR 100 Tm
1. Have calculator in “print” mode
2. Press [CA]
3. Hold [SET/%] key for about 5 seconds
5. Press [TAX+]
6. Press [SET/%]
Mar 12, 2008 | Casio HR-150TMPlus Calculator
Programming Tax+ button
Programming Tax Rate
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
The one below is the one you require.
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Feb 04, 2008 | Casio HR-150TER Calculator
Change Tax Rate
I found this on the Casio site. I think yours is a printing model. If it is use the 2nd set of instrucitons. Hope it works...
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Nov 27, 2007 | Casio HR-150TMPlus Calculator
How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
Pam
Oct 10, 2007 | Casio HR-100TMPlus Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Mar 13, 2007 | Casio MS-80TV Scientific Calculator
533 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
