Message will not go away after the paper jam has been cleared.Tried the obvious turning off Any suggestions?
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his
Lexmark X6575 printer (a similar printer). The resolution of the problem
once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam'
message, even tho' there was no paper jam in my lexmark x6575, but the
message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well
just underneath this there is 8 little roller feet that sit on top of
another silver/cream roller. Well in between these, in the very centre,
you will see a little black plastic nib like thingy...While the machine
is turned on, press this little black thingy (best to use a pen or
something like, as it's small) and what should happen is the
silver/cream roller will make a quick rolling motion....Hey! presto the
'jam message' disappears and the lcd screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope
this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Genius, only had the incorrect error message for an hour or so. Came on hear, read this tip and its gone. Perfect. Many thanks
The solution may work for the problem described but that is NOT my problem. A hinge that is used in open and closing the top is broken so the message is "close top" I need to find how to fix or replace the hinge.
Many thanks
I had the same problem and after trying to sort it for few days and I almost bought a new printer today.
Your advice worked and the printer is working well again
Athula
SOURCE: Lexmark x3350 printer has error message : clear
Fix: Inside the printer, amidst the rollers approximately in the center (easily accessible), was a small lever/pin... just move it over (I touched it lightly and it moved itself) Error message went away. Printer works
SOURCE: Lexmark X7675 error: Paper Jam (on printer control
Remove the cartridges. see any bits of paper left behind. Replace the cartridges. You will be asked to align again. Do this.
Hopefully, this will work
Good luck
luciana44
SOURCE: Lexmark T650 paper jam message
When you remove the back cover you'll find the fuserunit. Ther are 2 "sensorflags" at the exit of the fuser. 1 of them is stuck. Try to make it move again and the machine will work.
