a
asad Posted on Sep 18, 2019
I need alternate Optical Laser Lens for Technics SL dv280 the installed is now working more, i need alternate for long serving life please guide me
I have SL dv280 Home cinema There 5 DVD/CD changer
5 Related Answers
Anonymous
  • 112 Answers
  • Posted on Feb 29, 2008
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Feb 07, 2009
SOURCE: technics sl-dv250 cd/dvd motor
check on ebay
Anonymous
  • 6 Answers
  • Posted on Mar 01, 2009
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Anonymous
  • 1056 Answers
  • Posted on Nov 28, 2009
SOURCE: Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Seamus377
  • 99 Answers
  • Posted on Jan 01, 2010
SOURCE: FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
I have not Technics SA-DV280 User Manual Instruction the same needed to E-mail Please at my registered mail
We are FIXYA dot com, we are not Technics, and we don't have your registered email address. Technics may have it, you use it to log in here but _we_ don't have it.
No manuals for the 280, just the 290 sorry.
Technics-SL-DV-280-GN-SM - vintage hifi
www.vintageshifi.com > repertoire-pdf > pdf > telecharge
PDF Design and specifications are subject to change without notice. 2.Dimensions and weight are ... Sound processor: SH-DV280, Tuner/ Amplifier: SA-DV280,.
Technics SA-DV280 Stereo Tuner Amplifier Manual ' HiFi ...
www.hifiengine.com > manual_library > sa-dv280
Technics SA-DV280 · Specifications · Downloads · Comments · User login · Latest Comments · Gallery images · Latest Reviews.
Technics Stereo System SC-DV290 User Guide ...
audio.manualsonline.com > ... > Technics Stereo System
Audio manuals and audio service pdf instructions. Find the user manual you need for your audio device and more at ManualsOnline.
TECHNICS RSDV280EG - Service Manual Immediate ...
www.manualscenter.com > manuals > rsdv280eg-servic...
Jul 18, 2013 - Design and specifications are subject to change without. notice. ... Sound Processor: SH-DV280, DVD/Video CD/ CD Changer: SL. -DV280 ...
TECHNICS SC-DV290 OPERATING INSTRUCTIONS ...
www.manualslib.com > ... > Stereo System > SC-DV290
Technics DVD Stereo System Operating Instructions. SC-DV290 stereo system pdf manual download. Also for: Sh-dv290, Sa-dv290, Sl-dv290, Rs-dv290, ...
I have Technics SL dv280 5CD change and have no Operating Instruction
Please understand that you are talking on a public forum to regular people who offer advice
please do NOT post your private contact information here
Hello Sir, dear i have Technics SL dv280 Home Cinema Full system i wanna replace the SL dv280 with SL dv290, please guide me that it will work with rest pieces of the system
Hi Asad, I'm sorry to tell you that SL dv280 and SL dv290 are not compatible, they have the same connector, but different signal configuration
Do not try to test, because you could damage the devices
To work well, you must replace all of the devices with those of line 290
Regards Franco Dosil
Hola Asad, lamento decirte que no son compatibles el SL dv280 y el SL dv290, tienen el mismo conector, pero distinta configuracion de se?ales
No intentes probar, porque podrias perjudicar los aparatos
Para que funcione bien, deberas reemplazar la totalidad delos aparatos por los de la linea 290
Saludos Franco Dosil
http://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Technics-SLDV-280-GN-Service-Manual.pdf
https://elektrotanya.com/technics_sl-dv290_sm_html.rar/download.html
Sir, my SL dv280 Laser Lens have become so weak and con,t drive DVD, CD disc, so please guide me, from where can i get the same for my SL dv280,
Hello, has tried to adjust the emission of the diodes Laser, to prolong the life of the Reader, must have oscilloscope and the service manual of the device to adjust, to know where are the corresponding test points
you can also search the Internet for this reader's offers
I send you links of places of sale of SL dv280
I hope you can solve the problem
Greetings Franco Dosil
Hola, ha probado ajustar la emisi?n de los diodos L?ser, para prolongar la vida del Lector, debe contar con osciloscopio y el manual de servicio del aparato a ajustar, para saber donde est?n los puntos de prueba correspondientes
tambien puede buscar por Internet las ofertas de este lector
Le envio links de lugares de venta del SL dv280
Espero pueda solucionar el problema
http://www.aliexpress.com/i/32367272587.html https://www.ebay.es/itm/NEW-OPTICAL-LASER-LENS-PICKUP-for-TECHNICS-SL-DV280-/281391924940 https://www.ebay.co.uk/itm/NEW-OPTICAL-LASER-LENS-PICKUP-for-TECHNICS-SL-DV280-/281391924940 https://enacoaching.com.br/profilel/index.php?keyword=uqfukiruoocevf-p80531-ftoz http://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Technics-SLDV-280-GN-Service-Manual.pdf
What is difference between SL dv250 and Sl dv280?
Hi, I sent you a link to the Technics DV290, which is more similar to DV280
I hope you find it useful
Hola, te envio link del Technics DV290, que es mas parecido al DV280
Espero te resulte util
https://data2.manualslib.com/pdf/17/1693/169266-technics/scdv290.pdf?7bf5b4b505da498d44c1aed4aaaf94e0&take=binary
3helpful
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
