Question about LG Televison & Video
LG 32 inch tv picture upside down no remote - LG Televison & Video
Posted by Bill Bloomer on
5 Related Answers
Anonymous
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
Anonymous
  • 5 Answers
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
Posted on Sep 06, 2008
Anonymous
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
Anonymous
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
Anonymous
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Posted on Mar 21, 2010
My tv LED promac 32 inch the problem is iverted picture upside down. Pls help me or how can I enter service mode using universal remote control
Don't go into "Service Mode" you could make it worse. Possibly have a bad T-Con. Check E-Bay or shopjimmy.com for replacement.
Feb 02, 2018 | Televison & Video
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
LG LED TV 42 inch 1080p 120hz horizontal lines and upside down picture
Sounds like a main digital processor board fault. In other words, its main board should be checked. This is a very skilled work, and a normal user can't do it with ease. Contact any expereicned service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 25, 2013 | LG Televison & Video
I just bought a LG LCD 32 inch tv 2010 and the sound goes down after 20 minutes by it self is there any solution please help
If you are operating with remote I guess the remote is faulty. Try operating it with the remote placed in another room & observe if the sound still decreases, else the button(sound) on your TV is itself faulty. Since you have just bought it, its still under warranty - contact dealer.
If its the remote, then change the remote
Jan 02, 2011 | LG 32LG30 32 in. LCD HDTV
WELL MY 32 INCH LG THE REMOTE LIGHT ON THE VT IS OUT CANT TURN CHANNELS OR ANYTHING FROM THE SIDE BUTTONS OR REMOTE PLEASE HELP
Have you unplugged the LG TV, waited about 2 minutes, and plugged back in to try and reset the TV?
After you reset the TV, try using the key pad on the TV first before you use the LG remote.
May 18, 2010 | LG 32LC7D Television
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
