Question about Kipor Electrical Supplies
My Kipor 6500T Diesel generator runs but produces no power. what could be the problem. Am told there was an overload they connected a cooker.
Posted by bruce mutamba on
sherlywang
    Master:
  • 425 Answers
Reasons for excitation. There's not enough remanence.
If you need to have new diesel generator set in futurer, please contact company email [email protected] directly who can supply Cummins, Volvo, Perkins, Yuchai, Shangchai diesel generator etc.
Posted on Sep 18, 2019
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
Anonymous
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
Garry Clelland
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
thesnooper
  • 342 Answers
SOURCE: Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Posted on Apr 04, 2010
Jeff Chapman
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
My kipor generator runs but produces no power. What is likely to be the problem
We have a whole Help Center and Engineers dedicated to helping people fix their Kipor Portable and Inverter Generators.
In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Jan 28, 2018 | Kipor Electrical Supplies
My kipor KGE 6000 Ti generator overload light is on, and there is no current output.
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Jan 27, 2018 | Kipor Electrical Supplies
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Hi, My KDE 6500T wont start, i replaced the battery and when i switch start, i can hear a tick but no ignition ,and the battery cable become tooo work
Check engine isn't locked down, rotate by hand, then check starter motor, and solenoid. The click you hear is probably the solenoid clicking in.
Feb 24, 2015 | Kipor Electrical Supplies
What could be the problem if KIPOR KDE 6500T Diesel generator turns off when I switch the breaker on?
is it air bound , clear it out , or you have a short but I would go with the latter ,
Dec 03, 2014 | Cars & Trucks
Kipor ig6000 overload alarm
most warning and alarm's are set less than what the manufacture rating is. it's a safety feature without it we would overload all our stuff
Sep 23, 2012 | Kipor Electrical Supplies
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Electrical Supplies Logo
130 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
Robert Wooley
Robert Wooley
ray gallant
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
